Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 10-13-2014, 07:51 PM
  #10906
rchogfan's Avatar
Trader Rating: 13 (100%+)
I'm convinced mm will be better on my local low/medium bite clay indoor track with right setup. Love the corner speed it possesses. Interested in trying a rear stabilizer (sway) kit. Would a soft sway bar create more corner traction, if not.. What it's purpose? Thanks in advance.
rchogfan is offline
Old 10-13-2014, 08:53 PM
  #10907
cokemaster's Avatar
Trader Rating: 18 (100%+)
Could someone in this tread do me a favor? I would like to know the shock shaft lengths and diameter. Also the piston exact diameter in mm for the rb6. I would like to find out if I can use the MIP bypass1 shock valves that fits the rb6 for my schumacher KF/KR.
cokemaster is offline
Old 10-13-2014, 09:59 PM
  #10908
3srcracing's Avatar
Trader Rating: 29 (100%+)
Would anyone want to do a partial trade for a B44.2?
3srcracing is offline
Old 10-14-2014, 06:41 PM
  #10909
Whats everyone using as a shock package oil weight springs and pistons? Right now im using 1.6 2 hole int he front 1.7 2 hole inthe rear 35 wt front and rear
Jspires688 is offline
Old 10-15-2014, 08:34 PM
  #10910
3srcracing's Avatar
What upgrades would you guys say are needed right out of the box?
Old 10-15-2014, 09:04 PM
  #10911
rchogfan's Avatar
1). Aluminum steering rack
2). Aluminum rear hubs
rchogfan is offline
Old 10-15-2014, 09:37 PM
  #10912
+1
AlwaysLOSI is offline
Old 10-16-2014, 07:33 AM
  #10913
Hey guys I broke an aluminum steering bell crank last night and cant get a new one before saturdays race how bad are the plastic ones I still have the ones from my kit just wondering if they are worth trying?
Old 10-16-2014, 07:49 AM
  #10914
Gayosaka's Avatar
They are bad
You could maybe use the plastic arm as the one that is not attached to the servo link. It will be less abused.
Drive carefully too
Gayosaka is offline
Old 10-16-2014, 08:19 AM
  #10915
Does anyone know the amp draw of a 7.5 under high bite conditions ?
blingy is offline
Old 10-16-2014, 08:54 AM
  #10916
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
I ran the stock bellcranks with the alum. ackerman rack for well over a year and a half with out issues. Don't see any reason they wouldn't work. I just switched to the alum. bellcranks though, but kept the plastic kit ones as back ups.
Teufel Racing is offline
Old 10-16-2014, 08:58 AM
  #10917
I have had thecar since it came out and have only broken the stock plastic steering 2 times. It's plenty tough tough enough the only upgrades I have are the adjustable hangers and al .5 rear hubs.
Gitsum is offline
Old 10-16-2014, 10:23 AM
  #10918
hairymuffin's Avatar
Trader Rating: 105 (100%+)
i only have the exotek slider..the arms are stock plastic..had this setup for a full season..i have the full aluminum kit for when these break..i believe the plastic was updated from the 1st batch years ago
hairymuffin is offline
Old 10-16-2014, 11:11 AM
  #10919
3srcracing's Avatar
Does the Exotek slider accomplish the same feeling as the Aluminum steering rack?
Is $500 for a roller to much? 3 weekends old with almost all the upgrades you can get on it.
Old 10-16-2014, 12:01 PM
  #10920
most only use the alumium rack for strength..not sure on the feel? $500 is a lot for a used roller..350 tops for a car with all the options..i only want 250 for mine,another $100-150 and you can have most of the option stuff..you mainly need rear hubs..if you race stock the mip aluminum pucks
