Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 04-03-2014, 04:31 AM
  #10246
nickdawg18's Avatar
Trader Rating: 33 (100%+)
Originally Posted by ThePanda
anyone need a brand new built RB6 never run? PM Me
already?
nickdawg18 is offline
Old 04-03-2014, 07:39 AM
  #10247
Hi,
I have the Kyosho RB6 readyset.
Does anybody know what is the part number for the rear dog bones?
Mike
Lowza is offline
Old 04-03-2014, 11:27 AM
  #10248
ColbyRichards's Avatar
Does any one want to sell their mid motor parts? The whole set screws, bearings and pieces? I got a 6 again but no mid motor parts with it.
ColbyRichards is offline
Old 04-04-2014, 01:40 PM
  #10249
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Are any of you running the brick pack instead of a saddle pack in your mid-motor car? If so, how do you have it laid out? Servo, electronics, battery, motor?
Kraig is offline
Old 04-04-2014, 04:50 PM
  #10250
Gayosaka's Avatar
Lonestar does.
http://www.rctech.net/forum/11706025-post4493.html
Gayosaka is offline
Old 04-04-2014, 05:44 PM
  #10251
Super Moderator
Kraig's Avatar
Originally Posted by Gayosaka
Awe crude, I mean a square pack not a brick. Sorry!
Kraig is offline
Old 04-05-2014, 04:51 PM
  #10252
KalEl63's Avatar
Trader Rating: 13 (100%+)
I decided it was time to try the MM out on dirt since I haven’t had a chance to race on carpet for 3-4 months.
First move was to move my batteries as far back as I can get them.
This will be my starting point I then have a feeling I will most likely need to mess around with the following:
Adjustable hangers so I can go to 3.5 rear toe as my rear mount works well with that.
Swap out the flat arms for the kit ones.
White springs in the rear
And a heap of other settings no doubt
KalEl63 is offline
Old 04-05-2014, 05:28 PM
  #10253
bigdaddy13's Avatar
Trader Rating: 85 (100%+)
I was wondering too.. Was thinking about picking one up.
bigdaddy13 is offline
Old 04-06-2014, 02:54 PM
  #10254
kenny lutz's Avatar
Trader Rating: 38 (100%+)
I'm testing this soon
kenny lutz is offline
Old 04-06-2014, 08:19 PM
  #10255
Super Moderator
Kraig's Avatar
Well I stuffed it in the car with the speed control in the back. I am running a hobbywing 2.1 speed control and that appears to be larger than the most recently released ones. I wanted to put the battery in the back and then run everything else in front of it but that wouldn't work because of my electronics.
So here is what I ended up with, full size servo, square pack, speed control all down the middle. The receiver is on its side on one side of the battery and the caps and switch for the speed control are all on the other side to off-set the weight. I hope to run it Tuesday night in mod to see it does. My total weight is at 1632.
I didn't stray to much from my stock setup when it came to my layout so I could swap back and forth easily.
Kraig is offline
Old 04-06-2014, 08:21 PM
  #10256
Super Moderator
Kraig's Avatar
That was another option of running the square pack like yours but I didn't feel like cutting the plastic rails. Then it just dawned on me if I raise the battery mounts up a little bit i wouldn't have to do that. Maybe I will try that next time.
Kraig is offline
Old 04-07-2014, 09:11 AM
  #10257
Default First race report MM
Coming from a DEX210 that I just couldn't get along with, I built my first Kyosho in Mid Motor. I am the only one at my local track with a Kyosho buggy. The fellow races stared with envy, as others claimed mid motor at our indoor medium traction clay track would NEVER work as well. 99 percent run B4/B5 and 22, those seem to get a lot of attention. I'm actually ok being the only K driver yet alone only mid motor in the field dominated by popular RM setups.
Building this thing wasn't on the easy side without lots of internet help… THANKS EVERYONE on this forum. I used the Cody King setup with a few tweaks. No additional weight and battery in the middle position with 3.5 degree rear toe. After 1st lap I knew it had better feel than my DEX210. It turns more aggressively and jumps flatter just like other initial impressions. One thing I noticed is how much quicker it reacts when the buggy gets loose from improper corner entry. I run the Gold springs front and rear as we have lots of jumps, large and small. I also put the chassis protector on, as the rear of the chassis in mid motor takes a fair bit of abuse, this thing does slap -- 23-24mm ride height.
All in all I'm pleased and despite what others think I am staying MM. I don't know if it's the buggy itself or just a day where I was "on" but I managed to pick up a lap and my consistency has improved. My friend noticed trackside that my buggy was the only one that seemed smooth. He felt the competition looked like they were hanging on too much.
Anyways… here's a pic of my layout.
Vincent_Diesel is offline
Old 04-07-2014, 09:37 AM
  #10258
kenny lutz's Avatar
I did it this way because I didn't want the 70 grams extra from a square pack. I think the square pack will fell like the saddles. which I thought was lazy and unresponsive. also this should have more rear % then a square pack because I'm able to get everything farther back in the car. I will know more one I get to scale it and see where it comes in % wise.
Old 04-07-2014, 09:44 AM
  #10259
Trader Rating: 68 (100%+)
I, like you am the only Kyosho as well. We run on a low traction bumpy track and this past weekend we had our season opener. I was the only MM on the field and I started 2nd in the A Main and finished 2nd. Im usually bottom of the A Main sometimes B Main. Im running Tebo's Reedy Race Setup
Speedychris22 is offline
Old 04-07-2014, 09:51 AM
  #10260
kenny lutz's Avatar
I tried to run the 22 2.0 mm and was off 1 to 1.5 from where I was with my rb6
