Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 08-19-2013, 10:35 AM
  #7921
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by silveraider14
anyone?
Yes shorter = more gain but that does not always equal more steering, it depends on what part of the turn you need steering.
MikeXray is offline
Old 08-19-2013, 10:57 AM
  #7922
silveraider14's Avatar
I need more on power steering around a pretty long sweeper if that helps
silveraider14 is offline
Old 08-19-2013, 11:16 AM
  #7923
1armed1's Avatar
Trader Rating: 79 (100%+)
You have a few options.
Lengthen wheels base at the rear hubs,
Move battery forward
Stiffer rear spring
I would try them in that order.
Dayton
1armed1 is offline
Old 08-19-2013, 12:42 PM
  #7924
I will try lengthening the wheel base but I am also thinking of trying out some different front tires. Right now I am running ss ions in the rear and ss full slots up front with open cell foams
Old 08-19-2013, 01:39 PM
  #7925
MikeXray's Avatar
Are your rear suspension hangers wide or narrow? wide would help if they aren't already.
MikeXray is offline
Old 08-19-2013, 04:34 PM
  #7926
CanyonCarverR1's Avatar
Trader Rating: 13 (100%+)
Can you describe the difference in handling between the wide and narrow hangers?
CanyonCarverR1 is offline
Old 08-19-2013, 04:41 PM
  #7927
1armed1's Avatar
From post #1, Credit goes to Cpt.America
Wide Hangers: The wide hangers provide a wider rear track width. A wider rear track width does two things to the rear of the car: a) Provides a bit more stability over small bumps, and b) raises the roll center in the rear of the car - A higher roll center provides more roll resistance - More roll resistance means the rear of the car will roll less in the corners - Less roll means less traction gain throughout the corner. (i.e. use the wide hangers for more steering)
Narrow Hangers: The narrow hangers provide a more narrow rear track width. A narrow rear track width does two things to the rear of the car: a) Provides a bit less stability over small bumps, and b) lowers the roll center in the rear of the car - A lower roll center provides less roll resistance - Less roll resistance means the rear of the car will roll more in the corners - more roll means more traction gain throughout the corner. (i.e. use the narrow hangers for more rear traction in corners)
1armed1 is offline
Old 08-19-2013, 04:42 PM
  #7928
I have the wide ones on there.
I think the narrow give you more bite in the rear
  #7929
MikeXray's Avatar
Check out the first page of this thread, brandon does an good job of describing it.
MikeXray is offline
Old 08-19-2013, 04:59 PM
  #7930
Trader Rating: 22 (100%+)
easiest way to describe wide vs narrow....
Wide Hangers: Have more grip entering turns and through the middle
Narrow Hangers: Have less grip entering turns but more as you come out.
So if you are on a track is rough or loose, then I suggest Wide.
If you are on a high bite track that has grip and you need it to rotate, I would run Narrow.
You give up some stability with Narrow but gain grip on power coming out.
You gain stability with wide, especially entering a turn, but lose some grip coming out.
these are my observations anyway....
Bob Barry is offline
Old 08-19-2013, 08:06 PM
  #7931
KalEl63's Avatar
here are some tuning tips I found a while ago and are the best simple advise I have come across and have help me the most (I would credit the person but cannot remember the RCTech user)
Intended goal = More overall steering
Reduce rear toe
Softer front spring/stiffer rear spring
Add a small amount of front toe out
Thinner front shock oil (mainly for low speed steering)
Notes: These adjustments are to add general steering. For more in depth break down, see them below.
Intended goal = More off power steering
Shorten front camber links
Lower front link on tower side and/or raise link on hub side
Reduce front caster/front kick up
Add more Ackermann angle
Move front shocks out on the tower/rear shocks in on tower
Notes: As you tune for off power steering you'll likely see a reduction in on power steering. Also remember that off power steering is only when you're not on the throttle or braking.
Intended goal = More on power steering
Lengthen front camber links
Raise front link on tower side and/or lower link on hub side
Add more front caster/front kick up
Increase anti-squat
Reduce Ackermann angle
Move front shocks in on tower/rear shocks out on tower
Notes: As you tune for on power steering you'll likely see less off power steering. Also a car with lots of forward bite is going to progressively have a harder time maintaining on power steering as the rear wheels will fight to push straight forward.
KalEl63 is offline
Old 08-19-2013, 08:17 PM
  #7932
I am gonna start with changing the front camber links to be shorter and I think its got a little push cause the ions are so locked down on the rear
Old 08-19-2013, 08:38 PM
  #7933
erchn's Avatar
Hey guys,
I've been out of offroad for a while, but had a chance to run James Arluck's RB6, in mid-motor on a sugared track, at NorCal Hobbies on Sunday. That's the best car I've ever run, super dialed. Testament to the car and to James' setup ability. The car has ridiculous potential, I definitely look forward to getting one.
Ethan
erchn is offline
Old 08-20-2013, 01:45 AM
  #7934
Trader Rating: 19 (100%+)
Just installed the new aluminium rear hangers, made a massive difference to removing the slop in the rear end, the only slop I have now is from the aluminium hub carriers (or to be more precise the bearings, can wiggle the wheel and see the axle move about a bit).
They are also 3g heavier than stock if anyone was curious.
Shimmy is offline
Old 08-20-2013, 09:12 PM
  #7935
Just an FYI to those that feel the steering is inconsistent. Try moving your battery all the way forward. I did so on mine and the further forward I went the easier it was to drive it harder.
Gitsum is offline
