Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 06-04-2013, 06:41 PM
  #7096
Trader Rating: 68 (100%+)
Which o-rings are u guys using on the shocks
Speedychris22 is offline
Old 06-04-2013, 08:06 PM
  #7097
lbckevin's Avatar
Trader Rating: 107 (99%+)
Stock o rings work great.
lbckevin is offline
Old 06-04-2013, 08:25 PM
  #7098
RShockley's Avatar
i just started using the clear grooved o-rings. They feel great but haven't run them long enough to really make a good opinion on them.
RShockley is offline
Old 06-04-2013, 08:26 PM
  #7099
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I run the blue x-rings from traxxas. Work great, last forever, painfully cheap.
Cpt.America is offline
Old 06-04-2013, 09:06 PM
  #7100
gelshocker's Avatar
Originally Posted by skengines
We need Aluminum hubs from either Exotek or Yaiba.
Kyosho ones are never in stock!
This was reported earlier: Kyosho have discontinued the hubs and will be releasing V2 hubs in 0 deg (and 0.5 deg). Cheers,
gelshocker is offline
Old 06-04-2013, 10:18 PM
  #7101
steam's Avatar
Default v2
The New Kyosho V2 Hubs are supposed to be out Mid May
Must be Mid May next year
steam is offline
Old 06-04-2013, 11:20 PM
  #7102
gelshocker's Avatar
Try ChampRC they might have them. Cheers,
Old 06-05-2013, 10:27 AM
  #7103
What up?'s Avatar
Trader Rating: 14 (100%+)
I usually run the ORG03X (clear) x-rings.
You can also run the ORG03XR (red) x-rings but the clear are a little better.
http://www.speedtechhobbies.com/inde...=60_75_202_206
I have not tryed the Traxxas rings that Capt runs but that is another option.
What up? is offline
Old 06-05-2013, 10:29 AM
  #7104
What up?'s Avatar
I would wait on the V2's
What up? is offline
Old 06-05-2013, 11:51 AM
  #7105
Do you have a link to the ones Capt. uses?
JiuHaWong is offline
Old 06-05-2013, 01:02 PM
  #7106
Jerad8's Avatar
Trader Rating: 114 (100%+)
Traxxas is "The Fastest Name in Radio Control" so I can see how traxxas x-rings will make the kyosho faster I have been using the clear kyosho x-rings and they work great but also the stock o-rings work good as well, kyosho shocks are great.
Jerad8 is offline
Old 06-05-2013, 01:53 PM
  #7107
gelshocker's Avatar
I meant see if they have the V2s already. They did not receive the V1s after being notified were discontinued. Cheers,
Old 06-05-2013, 04:40 PM
  #7108
biggerT's Avatar
Carl's bulkhead is the bollo@#$ had one on mine for a while settled the rear a little and you can get to the ball studs without taking the tower off his front brace is a lot stronger too highly recommended
biggerT is offline
Old 06-05-2013, 09:16 PM
  #7109
Trader Rating: 19 (100%+)
Could someone please explain the differences between the kyosho arms and hubs, pivot block etc...
Such as the type B hubs and stuff?
Shimmy is offline
Old 06-05-2013, 10:32 PM
  #7110
Teambcw's Avatar
Trader Rating: 28 (100%+)
If someone is looking to sell or trade a Rb6 let me know. I am also looking to trade a really nice dex210 for one. Thanks!
Teambcw is offline
