Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 05-30-2013, 07:50 AM
  #6991
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Inconsistent? Mine was very consistent. It must be the dirt you run on. I ran Green compound groovies.
Wildcat1971 is offline
Old 05-30-2013, 07:59 AM
  #6992
Trader Rating: 22 (100%+)
yes, inconsistent. Ribbed tires can push then grab or steer smooth and then grab hard. Really depends on the surface and how many ruts are in it. We run on a very hard packed surface that will have a layer of dust on it. It's fairly low bite, so any 'grabbiness' on the front end is felt double on the rear. If it's early in the race day, or the track just hasn't deteriorated much that day, it's a non factor.
Bob Barry is offline
Old 05-30-2013, 08:08 AM
  #6993
skengines's Avatar
Trader Rating: 226 (100%+)
Anyone know a place that has the K Alum. Hubs in stock at a reasonable price?
skengines is offline
Old 05-30-2013, 08:41 AM
  #6994
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Strc has hubs. I've had 2 sets and no complaints. I have the .5 and the 0* I would buy them again and try are half the price if the kyosho hubs.
ryanpatrickgore is offline
Old 05-30-2013, 08:47 AM
  #6995
Tech Prophet
I had that issue with my tlr22. I tried some Suburbs up front and they were much smoother. If you have a lot of fluff though, they might not be great. We sweep the track here and it does not really break up much
  #6996
Suspended
Trader Rating: 23 (100%+)
Picking mine up Saturday or Sunday, so my question is.. What are the most common parts that break? As my LHS do not carry Kyosho. Thank you!
Team G Racing is offline
Old 05-30-2013, 08:54 AM
  #6997
Tech Prophet
well, front arms obviously. Rear suspension hangers, rack, rear camber block and I might get a set of front and rear towers, but those rarely break, but its possible. If you get the alum exotek rear suspension holders, then you can ignore that. Keep in mine a spare set of plastic ones is about the cost of the front alum hanger...which is the main one that breaks. read up on grub screws for the rear camber block, it "helps" with issues.
Old 05-30-2013, 08:57 AM
  #6998
pekow91's Avatar
Trader Rating: 45 (100%+)
Check out the first post. Capt. and the guys did a nice job of putting together a FAQ for the RB6.
pekow91 is offline
Old 05-30-2013, 10:02 AM
  #6999
aloksatoor's Avatar
Trader Rating: 43 (100%+)
After trying the front holeshots in m3 and m4, I won't go back to the groovies ever. Hook up much more consistently, that pesky breaking in ribbed tires is non existent. Glue and go pretty much. They do wear quickly though.
aloksatoor is offline
Old 05-30-2013, 10:37 AM
  #7000
aloksatoor's Avatar
Jconcepts making parts now for our cars
http://www.redrc.net/2013/05/jconcep...r-shock-tower/
Old 05-30-2013, 10:42 AM
  #7001
Anybody using carbon fiber front towers? Do you know if or how much weight savings it is? I would buy them just for looks my car is pretty dialed but always adding tricky bling parts
Old 05-30-2013, 10:44 AM
  #7002
aloksatoor's Avatar
No info on weight savings. I dont have a single piece of carbon in mine. My ocd won't let me run front carbons and rear plastics . So until someone makes a rear cf not for me.
Old 05-30-2013, 11:08 AM
  #7003
I run on a predominantly 8th scale / 4wd SCT track. They do their best by blowing it off and wetting it to keep the dust down but once that water hits, it's like driving on ice. Catch 22...
Old 05-30-2013, 11:15 AM
  #7004
Yeah, I'm waiting for the wing mounts.
Old 05-30-2013, 12:09 PM
  #7005
skengines's Avatar
I'm waiting for hubs! Hopefully JC makes some..
