Kyosho Ultima RB6 & RB6.6 Car Thread
#3376
RB6 is the best buggy I've ever driven though. I highly recommend it.
#3377
Those who have switched from a 22 to an rb6, what would you say the different handling characteristics would be?
Thanks.
Thanks.
#3379
KYOUM720 -Kyosho SP Front Suspension Plate (Type-B)
I believe is the right one
#3380
well.. not AT the pivot, but close. With a 2mm shim in the rear, the arm is so far forward that the very inner front of the arm hits where the chassis starts to taper inwards towards the back of the car. Just a smidge. I have a .5mm shim in front, and 1.5 in the back, and it's perfect. The arm is shimmed forward, and just barely no contact with the chassis.
#3382
I also bent one last night after some contact during a race. I was really surprised it was bent because the contact wasn't significant. I have heard of a couple others at my track also bending them as well, and we don't have many RB6's running (yet). Out of the three heats of stock buggy last night there were only two. I think that piece is a little bit soft.
#3383
That piece has always been like that in the RB5/RT5. If you hit something at the right spot, it bends.
#3385
#3389
I need so help! I was looking at some of the setups and most pros are running the number 2 shock hole on the rear arm. Are they drilling this hole out or running a different arm completely?
