3 Racing Sakura D3 CS Drift >
Like Tree2Likes
Old 01-17-2013, 08:29 PM
  #1171
pickled's Avatar
Originally Posted by Cloaked
My Sakura D3 is currently at the Dispatch Facility waiting for customs clearance
Cant even go and pick it up!
yeah my motor and esc are in melb so I have to wait till monday or tuesday for it to get here
pickled is offline
Old 01-17-2013, 08:55 PM
  #1172
Originally Posted by pickled
this is my shell
Yeah that should be fine
I'm waiting on a hobbywing 120A Xerun V2.1 and yeah racing 8.5T hackmoto combo from rcMart ATM
Ohh haha look at me not being able to read, your shell is super clean!
I guess I'll post a pic tomorrow of my current setup!
Isn't 120A a bit overkill for dorifto??
Might consider that combo for my sct though, looks like a solid deal.
Yeah the only reason why I'm considering BL now is I mainly run on not-so-short carpet tearing up my apartment at school. The silver can I've got in there is a little strained from the gearing I'm throwing at it.
Apartment drifting is super fun though, very technical, and a great distraction from that studying I'm supposed to be doing
saturnv7890 is offline
Old 01-17-2013, 09:00 PM
  #1173
Cloaked's Avatar
Trader Rating: 15 (100%+)
Im running a Hobbywing JustStock 45amp ESC and a Trinity D3 13.5T Motor and will be running a 80/18 gearing.
Should be enough to get the wheels spinning at a good speed.
P.S. - That sucks pickled I WANT MY CAR
Cloaked is offline
Old 01-17-2013, 09:11 PM
  #1174
Well that's reassuring!
Can't wait to start having some funds lying around haha
Old 01-17-2013, 09:58 PM
  #1175
Originally Posted by mrjfang
thanks pickled for fixing the links and I will definitely be ordering the parts once the alloy spur holder gets in stock
Also check out tqrcracing, based down south, fast and cheap shipping for us here in Cali.
They just got a lot of the hop ups in stock. So they might have what you need
That's where my latest order came from...and I have ordered from them lots of times
eunique is offline
Old 01-17-2013, 10:56 PM
  #1176
pickled's Avatar
I don't think so my LHS drift track is a traction race track as well and it's huge which sucks. they have drift comps but it's drift racing with up to 10 cars drifting at the same time, and they score it 1st 2nd 3rd across the line. I don't go to the comps I think it's retarded to run comps like that but anyway I'm going for that esc and motor combo as at the moment I'm running a 5.5T with the end point on my radio at 50% so it won't make much difference and it will be smoother being a sensored setup. I had a drift track set up in my lounge room for a bit but that was when I was learning to drift I could get around it now but I ripped it up ages ago when I threw a hissy fit about the CVD's falling apart because they weren't assembled correctly and I didn't know to check them
here is a fish eye view of my LHS's drift track
HOBBY HABIT twin drift
pickled is offline
Old 01-18-2013, 12:20 AM
  #1177
yeah! i love tqrc. thats where i got all my hopups so far. cheap shipping + fast shipping time is great. rcmart usually ends up being more expensive for me once I add in the shipping. The spur gear adapter is not in stock unfortunately. I just ordered the yok upper arms for the KPI mod today from banzai. Speaking of which, here is my list for the KPI mod:
2x 20mm turnbuckles
front suspension arms
4.8mm yeah racing derlin cups
15mm button scews
3RAC-BS48H5/PK - 4.8mm ball stud
my question: is this everything i'll need? i plan on using the turnbuckles on the steering arms so that it is easily adjustable, and from the pics i think the 4.8mm ball studs should work with the turnbuckles
mrjfang is offline
Old 01-18-2013, 12:28 AM
  #1178
pickled's Avatar
2x 20mm turnbuckles
15mm button scews
like this?
did you get some MST front uprights you might have to look them up on ebay
I used 15mm? might have been 10mm set screws in the front uprights with the 3 racing ball link on top must use thread lock this way
pickled is offline
Old 01-18-2013, 12:37 AM
  #1179
thanks for the pic pickled! i dont know what i was thinking. For some reason i thought the ball end went on the suspension arm haha
I think i found them on ebay, P/N 210239S for about $50
mrjfang is offline
Old 01-18-2013, 12:46 AM
  #1180
pickled's Avatar
yeah that's the ones in the pic, no you need to use 20mm set screw and cut the front arm at the cross brace a ball end goes on that, I used a tamiya ball end from a tt-01 for mine
pickled is offline
Old 01-18-2013, 12:48 AM
  #1181
Are they necessary though? would the stock knuckles work fine, but switching to the MST would yield better steering angle?
mrjfang is offline
Old 01-18-2013, 12:53 AM
  #1182
pickled's Avatar
You can get the plastic MST knuckles but you can't do the KPI mod with out them. I'd try to get used to it first before you go modding it anyway that way you'll know how much different it is. The KPI (King Pin Inclination) mod works because the ball links are offset what it does is modify the camber as the knuckle turns so you get a variable camber depending on the angle of the steering
pickled is offline
Old 01-18-2013, 01:35 AM
  #1183
here's my video from first week of January
http://www.youtube.com/watch?v=-43KA2ObWrQ
eunique is offline
Old 01-18-2013, 02:28 AM
  #1184
pickled's Avatar
your really starting to get good now I thought that was awesome
pickled is offline
Old 01-18-2013, 07:05 AM
  #1185
Because I want to use it as a front wheel drive racer, not a drifter. I think the geardiff of a Sakura S might fit, seeing that the width of the diff is the same. Maybe only the location of the pulley is different, but as I'm only using one center pulley I can move it to be in line with the diff? Maybe someone has tried a geardiff or balldiff in the D3 before? I know there are a lot of guys out there who don't like a oneway.
I'm not 100% sure but I think your right I think the Zero S should fit you will probably just have to move the pulley across. they're only 20 bucks I'd just get 1 and see
Tizer, PM me...I have one of those Zero S gear diffs...you can have it for $5 plus shipping. let me know if that works for you
eunique is offline
