3 Racing Sakura D3 CS Drift
#361
How and where did you get idler gear? Can you post pics so we can see your setup and maybe do the same if it works good? I'm going to do the spacer mod as well to the rear mount. Can't wait for the hop up parts for the D3. I keep checking every day to find them available.
Don't order from HKS hobby...I finally spoke with someone and they will take your order and money even though they don't have the hopups in stock yet...and wait until they get them in...holding onto your money
http://www.rc-race-and-drift-japan.c...oducts_id=2746
this is what I'm thinking of getting for the belt, but since changing it it's nice and tight so not sure now but it will probably stretch as it gets used more
#362
#363
good to hear that....I'm excited and can't wait for my order to come in from 3racing...broke my front belt and pulley was chewed through....can't wait to get the front one way and practice with that. My LHS has tight track carpet and I'm starting to get more comfortable with my 50:50 Zero S at the expense of my D3 CS being harder...so makes Zero S easier.
My shipment from 3racing is in New York..but I leave for vacation tomorrow...so I can't wait to get back and open my goodies!
That's a bad addiction when one can't wait to get back from vacation to open up RC parts!!!
luckily you get a 38T pulley with the one way but how is that happening to people my front pulley and belt are fine even when it was the spool
#364
Im going through that feeling right now, knowing my new D3 is either only a few minutes drive away, or its on it's way to me. Expect lots of excitement and build pics in the next few days... No building tonight, gotta work although, im tempted to start after work for a little....
#365
#366
#367
No oneway or Double cardan driveshafts yet, wanna see how it goes standard, but certainly will get atleast the one-way in future. I will try those settings to start off that you mentioned just to go by, and see how i go.
Cheers
Cheers
#368
lol, I know every order I've had I'm waiting by the front door (like homer simpson going "huurrrry uuupp") when I hear the postie only to have him drive past arghh the disappointment when he doesn't stop but when the goodies arrive it's so thrilling to go through them
#371
Are they Street Jam OTA-R31 hubs and kikaku knuckles??
looks like they stick out further than the stock hubs at second glance they actually look like the track is slightly narrower? How much toe in are you running?
#372
I'm watching for the postman daily for a Zero one-way from rc mart (now all sold out interestingly) & 16T &18T Aluminum Center Pulley Gears from 3 racing. These will reduce the CS to either 1.55, 1.75 respectively. No need to change out front pulleys, its pretty obvious 3racing intends you to replace the rear one only given its the only one with a post tensioner. Going to try and use the original 22t as a pulley tensioner off the post
#373
can i ask is there a reason you bought both types Pickled? i think that was your lengthy shopping list i was reading. Are the ssk drive shafts from the zero a worthy upgrade to get rid of chatter? Mine just started to do it super bad today after about 8hrs of running. huge vibration on full lock
I'm going to be getting some alloy pulleys in the coming weeks and replacing the diff pulleys with alloy ones but I'm getting better at controlling my drifts now so might just stick with this ratio for now
Changed the front camber to 5* its a bit better for transitions
#374
if 3racing dont start selling ther upgrades soon im going to do the street jam steering mod like this guy did
well now that i have 3 d3 i have to order everything 3 time lol
my parts should be in next week
here is what i got
3 18t pulley's
9 13t pulley's
1 oneway as i have 2 already
4 front belts
4 center belts
4 rear belts
after they come in there will be another order going for rpm ball link ends and all the 3racing pink spacer and ball ends
here is what i got
3 18t pulley's
9 13t pulley's
4 front belts
4 center belts
4 rear belts
#375
man you really like your D3's is it just so you can have different shells?? or are you going to have different setup's on all 3 -carpet -bitumen -vinyl? 3racing are going to be making parts just for you. lol
we need to look at modding the bell crank too cause it hits the bulkheads like your mates make the distance in the centre wider will also allow wider steering angles
