new to onroad touring
ok i have a tc4 club racer roller i wanted to race at a local track. the rules say
Touring Stock : 17.5 (blinky,no esc timing)2 cell lipo,spec tire.
Touring Super Stock : 17.5 (open speedo)2 cell lipo,spec tire.
i have a novak gtb 4cell and a Novak Ballistic Spec Racing Brushless Motor (17.5T) motor.
Which class would i run in? what is a blinky esc?
Sounds like Touring Stock. Blinky is a mode that the ESC flashes lights to show it is in a non boost/timing altered setting. The Novak GTB ESC and motor should be fine. The 4cell is your battery? NiMh? You will want a 5000 mAh 30C or better battery for that class. Check your local club rules or at least the rules where you plan to race. They may have battery limits too.
Super Moderator
I wouldn't worry too much about low voltage detection. In my 17.5 blinky with a 5000mah 40c battery, if I run for about 9 minutes, each cell is still only at 3.74 volts, nowhere near the usual 3.4/3.6v cutoff. By then, the motor is getting really hot anyway, so you'll be fine.
