Yokomo MR4TC-BD
#8433
True Francis !
I saddly experienced that they last only a few runs in Modified Class when used on the front (with the spool).
Better keeping them for the rear.
I highly suggest you to change for the stainless steel ones.
You can also use the Tamiya (44mm long) CVD with their own wheel axle.
Only issue: the outer bearing will be out for about 1mm, so you will have a front width 2mm larger than the normal. If you have no other choice, it's always good to know...
Slide
Slide
#8434
Trader Rating: 102 (100%+)
Uni
the Uni's will be a little smoother in transition..especially when doing an extreme sharp bend.
but I've gone thru a few sets in the front running 13.5..
the rear have shown minimal wear. I oil/grease them pretty much after every run to keep 'em smooth
(note: I find the LCG wears them more than my prior BD, ran the BD on carpet and currently LCG on asphalt)
but i do believe it's also partly how smooth you're with the throotle...I have a bad habit of just snapping the throttle when finishing off a turn so I'm sure that contributes to the wear.
I've never worn the Steels in front just greased them up often.
#8438
it feels very good on the track but usually they lack a little aggressiveness and precision and this is where the hpi springs gain their advantage in laptime
the yokomo springs are very progressive
the car "works" a lot more and on rather smooth tracks with flowing corners they generate a lot of steering and this is when yok springs are faster
i have tried xray springs a lot of times but always went back to either yok or hpi
#8440
the xray springs make the car roll very much.
#8444
I actually ordered the TiR cvds from them directly. Cost more but got them instead of waiting.
