Yokomo MR4TC-BD
#7471
#7472
im pretty lucky on the parts situation the local hobby shop seems too stock alot here and when i do order parts they always arrive on time. the austarlian destributor keeps a good stock of parts in thats for sure...
im thinking of buying the bd-m does it drive the same or better than the old one with the geometry of the car ?
the only change is the rear shock tower is 1mm higher than the stock BD one
#7474
Ive just started running the progressive shock springs and I have noticed that the end of the spring starts to slide over the adjustment ring on the shock body.
Has anyone else had this problem and what do you do to stop it happening.
Is Chris Granger still posting help on this thread, be good to see him on here again.
Rhys
Rhys
#7475
Rhys
Rhys
#7476
information; if using brushless with 3.5 or 4.5. remember to check and change the diff spring as often as possible. because i tighten the diff 1/2 to 3/4 turn back. the spring become weak, and you will start burning pulley again, like me. the new spring length 6.5mm or more and hard. after i use it for 3races become only 6.3mm, and very soft. and start melting the pulley again. just sharing my expirience, hopefully usefull...
#7477
#7478
i'm using tamiya msxx's alu diff (it needs some small mods on lathe to fit well..)
built with ceramic 3/32 balls ,yokomo's plates, tamiya screw nut ,spring and finally ceramic diff thust bearing.....it is very very smoot and lasts many runs .......i'm running mamba 7700 motor and track power lipos....
after 10 runs it is still smooth and firm......also i use a drop of threadlock on the screw aftere setted it well
Bye.....
Bye.....
#7479
Bye.....
Bye.....
can you tell me more detail about your modification to the al out drive?
are you using bd pulley or tamiya, the same teeth?
yokomo diff plate fit into tamiya out drive?
thrust bearing yokomo or tamiya?
thanks man.......
#7480
1..the tamiya outdrive has a little step of alu near the pulley that had to be removed to fit in bd diff housing......you need a lathe to make this mod....
2 you can use bd pulley
3 use yokomo's diff plates fit perfectly...
4 tamiya thrus beraing (i use a ceramic one...)
i think that is a good modification for BD...tamiya diff has plasic blades that save the outdrives....and the small diff screw has fine adjustment .....
also i 've seen titanium racing diff for BD......it's very nice ,has removable delrin cups and semms that lasts very long.....
here is a pic
and a pic of my car with tamiya diff fitted
here are a pair of pics of my new CREST japanese chassis....i still don't try it...but seems very nice in weight distribuition.....
Ciao
sorry for my bad english.
here is a pic
Ciao
#7481
here is a pic
Ciao
here is a pic
Ciao
Hi, where did you get a ceramic tamiya Thrust bearing?
#7482
from ebay...walawala bearing shop.....he has many caeramic stuff...bearings, diff balls..it is cheaper than rcshops and quick in shiiping.....,you'll save a lot of money.
Bye
Bye
#7484
entire thrust bearing......it has a ring with holes that holds the small balls between the plates.........
