Yokomo MR4TC-BD
#7144
I have one on my BDM that I am will to let go its new but mounted. Never had the chance to race the car.
Team Bomber top Deck....pm me if you are interested
#7147
Originally Posted by VooDooPH
anyone with set-up sheets for indoor asphalt with low-med grip, running rubber tires with 19T or 23T?
#7148
Originally Posted by DOTMAN
This question is for anyone...I'm looking for a stiff carpet upper deck for the BD. Does anyone know where I can get one?
#7149
In Chris Grainger's set up tips, he advises that instead of using the supplied 1.5mm black spacer that fits to the bottom of the steering hub (between the hub & block), to use the a black plastic .5mm and a 1mm blue alu spacer on top of the block. The trouble I can see is that the bottom king pin when fitting the spacers on top are too long, anyone know the answer guys.
#7151
Originally Posted by tantalus007
you could try masami's setup at the recent 2006 JMRCA at yatabe arena... i know someone who's running that setup... will let you know as soon as we meet in our tracks...
#7152
BD kingpins
Terryh,
You follow the book - use a black plastic spacer (from the knuckle moulding) on the bottom. You may have to shave it slightly.
A better solution I have just used is to fit the titanium kingpin set to the bottom, it consists of a top hat bush and a screw - perfect fit!
regards
Don
regards
Don
#7153
or just don't use one on the bottom at all - just ends up binding. I haven't bothered for years, doesn't create any issues for me.
#7154
Dan, can I ask what you used to draw those, thanks.
#7155
