Yokomo MR4TC-BD
#5611
I think they're HPI c-hubs but both AE and hpi look very similar from above. AE hubs need more modding to fit.
#5612
hi.
i got some cnc/aluminium steering knuckle (not sure what brand).
anyway i found that i had two types of CVA axles. one is shorter and one is longer.
the shorter one fits on the cnc steering knuckle.
the longer on fits on the standard plastic steering knuckle.
does the kit come standard with 2 types of front axle CVA's? one is shorter and one is longer ?
or the shorter cva axle is a hop up aswell.
#5614
wat r the part numbers for the hpi front hubs and wat r the difference over the yokomo ones?? thanks mark
#5615
anyone know whats the difference between the "O" and "1" steering knuckles?
#5617
Originally Posted by DOTMAN
the 0 have no offset. If you're looking from the side you'll see the part where the kingpin screws in is right in the centerline of the bearing. The offset is 1 mm offset towards the rear of the car.
#5618
#5619
"0"is just normal inline, like every other steering knuckle from HPI, Tamiya etc. "1"is 1mm trailing, drive axle 1mm behind kingpin. It's a bit like running more castor, smooth out the car a lot. I use it only on very big track with one-way. But most of the time I run spool now, "0" inline is always used.
#5620
i need to buy some more "0" steering knuckle. ( i got lots of spare "1" knuckles)
if i was to buy SD-415, does that refer to the "0" or the "1" knuckle? or you get both in the packet?
#5621
You need SD-415S(normal composite), or SD415SG(graphite). You get two "0" inline steering knuckles per bag,
#5622
Originally Posted by Jochim_18
I believe it's a AE C-hubs masami is well known on using associated parts. If you look at his LRP TC master setup of 2005, The C-hubs the he used on his BD is AE 4 degree C-hub.
#5623
#5624
Theyre not HPI parts there just like HPI parts, yokomo have made them and it looks like its working so expect them to be released sometime soon.
#5625
just going through my "1" knuckles. most of them are stripped. do you know the part number for the "1" knuckles aswell?
also is the graphite knuckles more stronger?
