Yokomo MR4TC-BD
#5461
Yep Mark E, southend and snetterton. Have you had any issues with the BD with the back swinging round? alot of other cars have not had this.
Mark
Mark
#5462
Nah, mine's normally pretty safe. How old are the tyres? I find that the back does start to go slightly when tyres are getting old.
What are you running toe in wise? 3 and 0, 2.5 and 0.5?
Stu
Stu
#5463
Originally Posted by aoizip
fpart:
I assume you will run the xpress race this coming weekend. I'm running a spool also.
my setup is pretty simlir to Chris Grainer's.. i'm running white spring in front, yellow spring in the back. silver roll bar in front, none in the rear. 40wt both front and rear. i might go down to 35wt in the rear to try out.
front shock in the middle hole / rear shock in the most outter hole.
.5 ~ 0 toe in front / 3 toe in the rear
thats what i run last weekend.
~Ming
~Ming
#5464
ok guys . just went to rebuild my carf for weekend it seem ive cracked my chassis which would explain y it was handling bit weird but hey. anyway do you think its worth upgrading to the stiffer chassis. i race on high grip carpet during week on rubber. and outdoor at weekend .
#5465
#5466
I think that it would be better!!
But the BD-002HG although it is stiffer than the standard chassis is the same thickness ( 2.5mm) , so it must be made fron another type of carbon!!!
#5467
#5468
Trader Rating: 102 (100%+)
stiff
the stiff chassis is quite a bit more stiff...
and with the thickness being the same...you won't have to make many changes to setup...
if you want to get the flex back....take the screws off the top from the steering post..and use grubs..give ya all the flex back...if ya ever run on carpet that deck is a must.
wish they would make the same for the LCG.
#5470
thanks a lot guys seems the stiffer chassis the way to go ill get that ordered
#5471
Originally Posted by pinggoy
hi just wanna know if the stock a arm of the original sd is compatible with the bd... just to be general, is the suspension parts of the sd compatible with the bd... im talking about the ssg sd...thanx
#5472
thanx...cause i just bought both of those car...its basically 2 for the price of one... and im just planning to put the sd aside but i notice there some parts that are compatible with the bd.the person that i both it with set the front camber lingkage to the place where the king pin is suppose to be placed...is that alright?
#5473
#5475
Hi Stuart i am running .5 and 2.5
any ideas
mark
any ideas
mark
