Yokomo MR4TC-BD
#5176
Originally Posted by yoko
The kit comes with 2x servo saver mounts part # BD-200P these seem to just post for the bell cranks, does anybody know how these are servo savers?
YOKO
YOKO
The car does not have a servo saver, but you can make the CGM one fit as stated, also some have used a Tamiya servo saver.
#5177
only ran Bd twice broken 2 servos, fitted a cgm servo saver and broke ackerman plate.
i have glued the outer edge of new plate. i hope this will help.
shame they dont make these out of something like ally.
YOKO
YOKO
#5179
Originally Posted by xxxkat
Is this breaking the ackerman plate from big hits or little hits? Just wondering if i need to stock up on them.. I don't hit to much stuff but when i do I do it right..
#5180
BD Servo saver
Thanks for all your replies.
I broke the plate hitting the side barrier on the track didnt hit it very hard, i think it was just the fact that i had full lock on.
they do seem to be very weak.
i did think about getting some made out of 3mm carbon fibre then putting a washer under the bearingso it still moves freely on the bell cranks.
Yoko
Yoko
#5183
Originally Posted by pops
It would be good to have a back up plate. Be sure to CA the outside and the ball stud holes, including the holes for the bearings go. That will take a little slop out of the steering at the bearings. Not may places have tougher boards than Speedworld and we have only broken one plate in one year. That plate was not CAed. Best bet would be to use the CGM servo saver as insurance. If you don't, stock up on a couple of extra servo arms at $2.50 per pack. You get 2 arms short and long for each type of servo.
#5184
I bought 4..along with every other part than can break,Here in no track land not to many shops carry Yokomo parts..If i want to race it's at least a 45 min. drive,I'm racing the whole day..
Mike,
Get some extra hinge pins you will need. and replace the stock center shaft with steel hollow shaft. Speedtech have them on stock better get now co'z this shaft is hard to come by.
#5186
Originally Posted by Jochim_18
I haven't break any steering plate since I move the tierod on the bottom of the plate. But I got a couples of extras incase I needed it.
Mike,
Mike,
#5187
Trader Rating: 102 (100%+)
POP off also
I had the same problem for a while, slightest bump or tap and the links would pop off, I ended up switching links to top and using Associated ball cups or the HPI heavy duty cups (stamped with HPI logo). Never had problems after that.
I wasn't sure if Yok made a heavy duty or grippier version.
#5188
Originally Posted by coons88
Recently I have had a problem arise with my steering, after big impacts the right hand steering linkage pops off. I run them on the under side of the ankerman plate. Would this just be worn ball cups, and time to replace them?
#5189
I think that Rocketron is considering making some custom ackerman plates that will not break, if he can get enough guys interested. He needs a fair amount of guys interested in buying them to make it worthwhile. Anybody interested?
any interest? PM me would be easiest
