Yokomo MR4TC-BD
#5071
hi,
any1 got the part number 4 the rear suspension mount used on chris crainger
car
car
#5072
Try that.
That shud help
That shud help
#5073
Ballcups are from the BX buggy, fit alot nicer with no play. You can also go one further and fit the BX balljoints which have a 2mm hex in them.
The rear mount on the front are the new style one piece ally versions, these allow you to put them on straight. The standard 2 piece ones you can put on at all sort of angles if not paying attention. (try it) Part no for car rear front is SD-300RF and the car front rear is SD-300FR.
By running the car rear front on the front it gives the suspension pins a slight bit of toe out, increasing steering reaction. To do this you have to file 1mm off to keep the roll centre the same.
#5074
#5075
No sure by replacing the "Split Type" suspension mount "F" with the "R" will have similar Tou-Out effect instead of the one-piece type "R" block??
Noted that the belt will have to go below suspension mount if using the one-piece type.
#5076
#5078
what is the advantage of the one piece over the two piece
#5079
#5080
Originally Posted by Jochim_18
To be able to do this what do you have to file?
#5081
So putting the "new" SD-300RF in the FR position on the car, will result in a slight inboard toe out situation. This must be because it is slightly narrower than the SD-300FR, is this correct?
How/why will inboard toe effect the handleing of the car? Do you have to set the outboard toe to its original setting, or just run with the slight increase in overall toe?
Will the SD-300RF fit directly to the FR position without modification? I understand that this will effect roll center and will need to remove 1mm in order to restore factory roll center settings.
#5082
Originally Posted by pops
John, I have a question, hope you can answer this. Being that the old rear front suspension mount (SD-300RF) will mount 1mm higher than the newer mounts, is Chris running anti-dive or is he shimming up the front suspension mount to make the front a high roll center and level? I can't tell if maybe he took off a mm on the R suspension mount and has a shim under it?
No antidive.
#5083
#5084
#5085
