Yokomo MR4TC-BD
#4906
Originally Posted by DirtyDog3375
Does it come with a spool? and how do the new drive shafts compare with the older ones? (do they still break?)
The driveshafts are like the ones from the SDW but beefier (according to an SDW owner), personally I'm not sure.
Still doing chassis prep.
#4907
Hi,
@H.Nilsson: Do you can read this? I think my Japanese is a bit rusty.... What body did he use? Which A-Arms? And what are all the notes at the bottom?
Cheers
Chris
Cheers
Chris
#4908
set up
Originally Posted by speedy-932
Hi,
Cheers
Chris
Cheers
Chris
Body.try ride honda 2 and yoke 3.1 wing = neutral
ride stratus 3 , protoform stratus 3 + yoke 3.1 wing = more steering
#4909
Hello yokie boys.
I have a question about the trailing steering knuckles, i have found a similar option for my 415, and i just want ot know what effect they have on the car?
Sorry if it has been replied ot already, i looked back through the last half dozen odd pages nad could not find a reference for it.
Bradd
Bradd
#4913
Ho Does anyone know the stock setup or a good one for the Masami Edition BD. I just got one and it really didn't have any setup. I couldn't figure out which springs should be ont he front(white with pink or white with orange) Please help.
#4914
Almost done with my Build! Here are the noticeable difference from the BD.
The rear tower
the steering assembly, which clears the belts
the hinge pin mounts, on the front rear and rear front.
the CVD's, but I think its better to use steel for the front, well if you crash like me-- then change it, but if you drive like masami then stick with it hehehe
the white belts and titanium screws and the bearings which you can really notice when you spin it.
It also ha a "1" on the front knuckles
Here are some pictures, not done with the shocks yet.
I also changed the rear hubs (i have an extra one), used .06 spurs.
fpart: just follow the stock settings first, (it's masami's) just change it after a few runs if you are not comfortable with it. My friends run theirs yesterday and said the steering was more agressive, with regards to the springs will get back on you, my instructions is in Japanese some has english in them.
The rear tower
#4917
The rear driveshafts are UJ versions. I don't have a part number but they come in the Grainger kit. A spacer is required between the bearings in the hub to support them though, and this reduces wheel wobble and spreads the bearings further apart. They use these driveshafts because they are supposed to give more steering and corner speed, its debatable
#4918
Originally Posted by v0rtex
So, the masami doesnt come with white belts? Unless you've just got the standard BD instead of the Masami BD...
#4919
Trader Rating: 51 (100%+)
Yo fpart, ygpm
#4920
I do not have a part number for the blue aluminum CVD's. They are much lighter than the steel version, but they bend easily.
Better to get the steel ones!!
