Yokomo MR4TC-BD
#4666
Originally Posted by Dan Hughes
Ali any chance of some of the Grainger tips and setups? Also the SDW arms could be going out of production, going to get clarification though before making any more of it.
Yes, it definitely would be great if someone who bought the BD Grainger edition could post the tips and setups to the BD community.
thanks !
#4667
Originally Posted by utieh
So those are not major improvement over the actual BD I thought it had revised bulkheads or stuff like that.
Thanks for the info.
Gilles
Gilles
#4668
Originally Posted by pops
The Masami Edition has all the stuff and changes Masami used at the Japan Nationals. Different shock towers, Bomber white belts and a few other goodies. I don't have all the spec's yet. I would assume that sooner or later the other parts would be available seperately.
#4669
Originally Posted by mike ivy
I just put a set on my BD and it seems to me It steers better the arms narrow the front width a mil or two try it out you may like it
Thanks mike, i will, but right now our LHS doesn't have the sdw arms in stock...
could you clarify "steer better"? like more initial steering? or more mid to exit?
thanks - jason
#4670
Originally Posted by asw7576
As promised....
hi... what does adding washers underneath the steering do? i already flipped my steering links to eliminate the bumpsteer, but retained the washer underneath the bell crank and not under the knuckle.
thanks - jason
#4671
Originally Posted by coons88
Just found out about this: New Masami Special BD
Apperntly it says something about new shock towers and new drive train.
But not much info at this point.
what's the body that masami is using?
#4672
Hi,
some news about the Masami Special:
-Super Precision ball bearings (14pcs)
-Team Bomber SP belts
-Titanium screw set
-Graphite plastic parts
-Titanium coated shock shafts
-New front and rear shock towers
@highwayman: He was using a Dodge Stratus 3 AP.
Cheers
Chris
-Titanium screw set
Cheers
Chris
#4673
thanks - jason
thanks - jason
On the carbon fibre steering plate I suggest to sandwich it with thin washers to avoid cracking.
I use Mugen MTX4 connectors and ball link connectors.
#4674
Originally Posted by speedy-932
Hi,
-Titanium screw set
Cheers
Chris
-Titanium screw set
Cheers
Chris
#4675
Trader Rating: 51 (100%+)
Hey Highwayman ygpm I got some info for ya
#4676
Dan Huges, ygpm question for ya
#4677
What is the right part number for the bd servo post that holds the bell crank?
is it BD-202P or BD-200P? or other? coz i bent mine up when trying to take it out for cleaning... stupid me...
Thanks for the help
~Ming
Thanks for the help
~Ming
#4678
Originally Posted by Ralf
Hi guys,
thanks !
thanks !
1. due to using the lower hole on the c-hub, the kit now comes with a 0.5mm spacer and a 1mm spacer to go on top of the steering block, to remove play. He also explains the handling differences witht he holes, "the upper hole gives more aggresive steering mid-corner"
2 THIS IS VERY IMPORTANT! This regards the shocks. To put in a nutshell, trim 50% off the stem of the triangle piece, and put it in upside down. This allows more oil under the piston, and more grip (according to him!)
3. kit comes with RS-14 (3x1.2mm) pistons
4. rear hubs are built with a spacer that slots in before the inner bearing, this is because the rear driveshafts are different.
5. remove material from SDW arms
6. explains the ackerman differences, also whether to mount the links above or below the plate. Doesn't matter, but when running more than 1mm under susp. blocks, put them on top otherwise they will hit the susp. mount
7. removing play from steering plate: line bearing holes with thin glue
8.belt tension, firmer belt=more traction, looser causes drag
9. explains why battery strap isn't included
10. explains 0 offset hubs, give more steering
That's the included grainger booklet summarised a lot, it then includes all of his BRCA setups.
The car is great, comes with 2 spools etc but there are a few problems
1. in the diff/pulley building bag, which have 2 pulley bearings and 2 diff bearings. I was given 4 pulley bearings, which have a smaller hole. With these the diff can't be built, luckily I have old diffs around and used some old bearings.
2. The instruction book isn't any different, and it's only through experience I knew how to build the locked centre for example.
But it's great!
#4679
That is some good info. If anyone needs setups put into PDF's PM them to me and i will post them. Ali if you can get Chris's snetterton, WRLC and Barham setups to me that would be great!
#4680
What is this??????????
