Yokomo MR4TC-BD
#3691
Trader Rating: 51 (100%+)
Hello there sam_smith here ya go hope this helps
RaySpeed
Spring Rating
Gray 19.90
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.20
RaySpeed
Spring Rating
Gray 19.90
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.20
#3692
Originally Posted by rc-zombies
anybody know the # of teeths the front and rear belts are?
lmk thanks.
lmk thanks.
and I believe that the back is 62
Hope this helps
jim
#3693
Ok, Quick question.
Im moving to a BD at the moment i have all 48dp pinions, so for the moment im going to be sticking with 48dp.
My Question is, what teeth spur gears will i need? and what make of spur gears fit the BD?
Any Help Much appreciated
#3694
I believe an 81 spur is a good one to have
#3696
Originally Posted by TC_Tuner
Had my new BD on the track for the first time. ran very good outta the box (stock rubber).
I did have one problem. The carbon steering rack broke, quite easily. It cracked right where the ball stud for the steering linkage is attached.
I've already contacted Speedtech and Yokomo direct, neither have them instock.
Given how easily it broke, I'm not exactly excited to replace it with the same part. I do not know any other options here. Does anyone else?
Maybe it was a freak think. I'm interested to know if others have found this part to be fragile.
TC_Tuner
TC_Tuner
Were you running a servo saver? That might have helped.
#3697
Originally Posted by Scho
Ok, Quick question.
The stock spur is xenon 78T. I'm sure you could go larger if you want. I recommend the xenon spurs that speedtechrc sells. Others will fit, robinson, etc.
#3698
Thanks for the help guys
#3699
Steering Knuckle
Hi all,
is it me only or does anyone else experience the top kingpin for the camberlink stripping the screw threads in the steering knuckles? Will changing to aluminium knuckles help?
Thanks.
Thanks.
#3700
#3701
TC_Tuner
TC_Tuner
#3702
Originally Posted by v0rtex
Yes, I had the same problem on the weekend just gone. I think the Alu knuckles would do the trick, but the Suzuki ones are almost impossible to find at the moment as they're machining all the Aluminium for the BD and LCG.
Here's a link:
http://www.speedtechrc.com/store/ebp...nid=243&id=845
#3703
Hi all,
Thanks.
Thanks.
Best bet is to buy the Ti light weight king pins, this keeps the kingpins going in straight and from binding. Most people overtighten the top king pin, just screw it in a less than a half turn once it feels tight. Use the Ti kingpins in the bottom.
#3704
Reckon if those made for the SD works on the BD too?
Here's a link:
Here's a link:
And they've been out of stock since before the BD came out.
