How can I tell if Im racing on a "high-bite" track?
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
I've been racing at the same asphalt track for about a year and a half now so its really all I know. But how can you tell if its high, medium or low bite? Is there such thing as low-bite carpet? The track I race on is sealed asphalt, so I'm pretty sure its at least medium-bite.
What I'm really trying to ask is, what is the distinction between traction ratings, and how does one classify a track's traction?
--Mike
--Mike
Oh yea, and how does the car set-up change for the varrying amounts of traction at different tracks?
I'm not a noob, Ive just only raced at one place......im loyal like that
I consider high bite as in cars traction rolling. And too much bite when everyone is traction rolling.
Super Moderator
Pretty much. If you see alot of racers flipping because they have too much grip, then that's definitely what I call a high-bite track, while if many are spinning out alot, &/or can't get their cars to turn because the whole car is sliding outside in a corner, that's a low-bite track, & medium-bites ones are, well, somewhere in the middle. And as for how a car's setup changes for those kinds of conditions, most of what has to be done is use softer tires for low-bite surfaces, or harder tires for high-bite ones, & you can also see people using thicker shock oil & harder shock springs on hig-bite, & thinner oil & softer springs on low-bite ones(& there are plenty of other adjustments to try, but those are the biggest)....
