Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 09-23-2008, 05:43 AM
  #13906
Thank you STLNLST
Originally Posted by mangoman
You should only really need the belt tensioner for the modified motors (maybe a 10.5) i have mine always fitted out of habbit.
In the faster classes i find it helps to stop the belt from flipping.
Thank you mangoman
We do run mod outdoors and 10.5 indoors, yes the belts do flip over unless they are very tight so if the tensioner will help we'll give it a try.
Thanks again for the help
Lazer Guy is offline
Old 09-23-2008, 07:13 AM
  #13907
mangoman's Avatar
Trader Rating: 11 (100%+)
No Worries....
My understanding is that a tight belt generates more friction however a loose belt and it will either slip/flip. Someone please correct me if im wrong....
I suspect running the belt too tight will also result in higher wear of the belt, while if the belt is slipping im sure that is also not good for the teeth on the belt.
mangoman is offline
Old 09-23-2008, 07:40 AM
  #13908
TPhalen's Avatar
My 2c.
I run my front belt a with cam notch at the 11 o'clock position (if you are looking at the diff from the drivers side...cam notch pointing to 11 o'clock). This makes the belt somewhat loose and friction free.
My rear belt, however, is set with cam notch at the 3 o'clock, or almost full loose.
I haven't had any problems with the belts flipping over or skipping while running 17.5 or 10.5. If you're going to run mod, I would adjust the cams 2 notches tighter (front, I think, at 9 o'clock, rear at 12, or maybe even 11 o'clock). With the additional power you will skip them for sure.
TPhalen is offline
Old 09-23-2008, 08:36 AM
  #13909
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally Posted by TPhalen
My 2c.
Thanks for the info.
STLNLST is offline
Old 09-23-2008, 09:06 AM
  #13910
cyclone speed's Avatar
My 2c.
whats the cam notch ?
cyclone speed is offline
Old 09-23-2008, 10:24 AM
  #13911
TPhalen's Avatar
If you look at the bearing holder (also called a cam), there is a notch in it so you can align the left and right together. Thus, a cam notch!
TPhalen is offline
Old 09-23-2008, 11:22 AM
  #13912
tomracing's Avatar
first 1/8 off road and already back at touringcars
can you say: "man on a mission"?
go hara!
source: http://y-trail.de-blog.jp/
tomracing is offline
Old 09-23-2008, 11:32 AM
  #13913
oh ok but when you said from the driver side do you mean from the midle of the chassi and and you look outwards or you mean you look from the outside to the inside of the car.
Old 09-23-2008, 11:47 AM
  #13914
TFR
TFR's Avatar
Where can I buy the Cyclone TC for $379 that is in stock?
TFR is offline
Old 09-23-2008, 11:55 AM
  #13915
KHoff7's Avatar
Good luck
KHoff7 is offline
Old 09-23-2008, 12:38 PM
  #13916
ShaunMac's Avatar
go hara!
can you say: "It's his job"
ShaunMac is offline
Old 09-23-2008, 07:21 PM
  #13917
TPhalen's Avatar
Sorry.
Yes, looking at the side of the car from the drivers side.
TPhalen is offline
Old 09-23-2008, 07:39 PM
  #13918
shadow102's Avatar
Trader Rating: 21 (96%+)
go hara!
whats with the Hara mullet? And the spray bomb practice bodies?
shadow102 is offline
Old 09-23-2008, 08:29 PM
  #13919
mangoman's Avatar
So where do i get a spray bomb from and what's its projected coverage range!
mangoman is offline
Old 09-23-2008, 09:58 PM
  #13920
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Syber Serulean
given a 6cell setup, i am now switching over to lipo in my cyclone with 17.5 What i want to know is what necessary as far as tuning/setup changes when going from NIMH to LIPO? The car was already balanced with weights with the nimh setup so i figure with lipo i need to re-balance it...anything else?
anybody got any insight?
Syber Serulean is offline
