Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 08-03-2008, 05:28 PM
  #13216
shadow102's Avatar
Trader Rating: 21 (96%+)
Originally Posted by cyclone speed
hi i would like to corner faster with my cyclone moor speed what should i change please it will be very helpfull . If you need any information on what i am running ask me and il tell you i really need help.
post your setup, what tires are you running and what body? and what exactly is the problem you are having
shadow102 is offline
Old 08-04-2008, 12:48 AM
  #13217
cyclone speed's Avatar
HI , i have a mazda RX8 I have sorex 28R tyre and my probleme is that when i corner i have to break hard to be able to corner without drifting , so it means that i loose time . What i would like to do is to corner faster without drifting but as i said i cant corner faster without drifting.
OK my set up is :
108 spur and 35 pinion
2mm spacer between the upper bulkhead and the inner pivot for front
and 2mm between upper bulkhead and inner pivot for rear
5mm front ride height
5.5mm rear ride height
4mm before the tyre lift from the ground (droop i think)for front
3mm before the tyre lift from the ground (droop i think) for rear
standart suspension 3 holes ,1.1mm each ,40w oil standart spring silver rear gold front
camber 1.5 all around
castor 4
wheelbase is standart
i have 1.5mm shims under the toe block rear
and 1.5 mm shims under front toe block and 2mm shim under the rear toe block at the front ( if i not very precise or not explaining propally please tell me)
0.75toe angle front
and standart toe angle rear
4mm ackermann
and i think thats it
for the elctronics:
lrp5.5turn gearing 7.5 (108 spur 35 pinion)with novak GTB 1st brushless profile with gemini 2 transmitter with micro 41 mhz receiver and T2M diamond digital servo (0.12 @ 60 , 13 kg torque) and finally i have 1 pack of orion SHO 4200 batteries , + 1 pack of demon ep 4200 + 2 pack of LRP hv2 vtec 4200 bigmama
Thanks alot if you could help me out
cyclone speed is offline
Old 08-04-2008, 01:11 AM
  #13218
grizzle's Avatar
Location: Filipino Contract Worker in Khobar, Saudi Arabia
Default rear toe in
Guys... can anybody confirm that uneven rear toe is caused by the rear hubs? I replace the rear hubs with my pro4 spare rear hubs and I supposed they are not molded right also... I have yet to try other brand rear hubs. Have anybody get around this problem other than buying the aluminum rear hubs or changing to tamiya 416 rear hubs and pins?
grizzle is offline
Old 08-04-2008, 03:54 AM
  #13219
shadow102's Avatar
Without diving into your setup much at this moment change your body out to a DNA2 or Mazdaspeed6 that may actually help your situation alot. When you say drifting is all four tires sliding out or is the rear end washing out?
Old 08-04-2008, 04:00 AM
  #13220
nope its only the rear end that would loose control and then my car would spin
Old 08-04-2008, 04:04 AM
  #13221
and sorry i forgot to say that when i want to corner faster my car would either underster or sometimes it will loose control at the rear . But it will mainly understeer that also my probleme
Old 08-04-2008, 04:07 AM
  #13222
k_bojar's Avatar
Trader Rating: 30 (100%+)
I ran the RX8 and its a very stable body - almost on par with a mazda6, believe it or not...
It sounds like you are missing your breaking points, ok not breaking point per say, just a point to let off the throttle - I'd try breaking sooner and not drive so hard into the corners...any reason why you are running 28r? is that what most guys at your track are running? I thought 28's were more of a colder weather tire (I could be wrong - its been a while since I ran sorex)??? I thought 32's were more of "hotter" weather tire?
k_bojar is offline
Old 08-04-2008, 04:16 AM
  #13223
Im running 28 because most people at local track use them and just to say that i dont know what does on throtle or off throtle means so i wont really understand . I think my car suffers from understeer.
Old 08-04-2008, 04:24 AM
  #13224
k_bojar's Avatar
I'm not even getting that complicated...
all i mean is that it sounds like you want to run full throttle into a turn, have the stick and make the turn...what it sounds like to me is that you need to slow down more getting into the turn and then see what happens...
too much speed in a turn will cause the rear end to spin out on you - as would the need to slam on the brakes...
so pick something on the track as a breaking point - and when your car gets near there, let off the throttle so the car slows into the turn...now you should be able to make the turn without spinning and loosing as much time...believe it or not, even the "fast guys" back off their throttle when they race - its just a lot less noticable for them since they are normally way more consistent then the average driver...
the only other thing I can think of is - how tight is your rear diff?? does the rear spin freely or does it seem tight?? if its too tight, that will add to you spinning out effort...loosen the diff up until the rear spins freely - and adjust as needed...
I wasn't thinking one time and did this to my rear diff and couldn't figure out what was wrong, until I had another driver's car in my hand and spun his rear wheels...then I went "doh!! I got the rear diff too tight"...I loosened it up and the issues went away
k_bojar is offline
Old 08-04-2008, 04:33 AM
  #13225
thanks i will try all your recomendation . But id like to know about droop : when it say 5mm droop on the setup sheet of a pro does it mean that when the pro put the droop guage it will show 5mm or does it mean that the wheels lift from the ground at 5 mm over the ride height .
And could you tell me the description of on throtle , off throtle , on power steering and off power steering .
Old 08-04-2008, 06:27 AM
  #13226
Coldn's Avatar
hy every one, i have a Hara Edition, but i want to know.
I was thinking in buy all the hop ups, to convert my Hara edition to the TC edition. Does it worth, pay for all the ups
Coldn is offline
Old 08-04-2008, 08:01 AM
  #13227
RE cyclone speed
if you are having problems with the rear of the car, i would advise a softer raer brace/ deck ( make your own if you already have the 2mm frp one on of the cyclone TC) as it will increase rear end flex....
re coldn
the hara edition is a very good car.
You will send £'ssss buying all the individual hot ups for your hara edition over time, so probally best to bite the bullet and buy a TC.
blazer2 is offline
Old 08-04-2008, 09:29 AM
  #13228
Khador12's Avatar
What body is everyone using for rubber tire and asphalt?
Where can you find the 1.1 3 hole pistons and the 1.2 sway bar in stock?
Khador12 is offline
Old 08-04-2008, 10:01 AM
  #13229
1.1 3 hole are for the pro 4 but work perfectly fine with the cyclone cause i use them:
http://www.apexmodels.com/product-se...&title=tune_up
for the body i use the mazda RX8 as good as the mazda 6
for the sway bar:
http://www.apexmodels.com/product-se...sories&id=9011
Old 08-04-2008, 10:37 AM
  #13230
Khador12's Avatar
Thanks for the help but it seems that they do not ship outside the EC and I am in the United States.
Khador12 is offline
