Hot Bodies Cyclone
If you replace the diff screw with the heavy-duty diff screw from the Cyclone D4. If you break this as well, it could be due to some other factor.
replace to HB Titanium Diff Skru......hehe..
Diff
Thank you
Are you using the aluminum outdrives? I found that when I had my car the hole the diff screw went through wasnt big enough and the diff screw was actually threading into the outdrive. I switched to ae diff screws soon after getting my car, and once I found that the screw was threading into the outdrive and fixed that, I never broke another one.
If you find yourself stuggling for traction try these:
-HPI high traction A-arms
-Remove roll bar at the end you need more traction.
-Reino's Marinade/Ragu traction compound - this stuff is great!
-Tire prep is VERY important in rubber tire racing. A good set of tire warmers can really make a difference.
Good Luck!
Good Luck!
can someone tell me what your using to get your brushless powered cars down to 1500g weight? im currently on 1549g with titanium screws and LW bodyshell.
Warren
Warren
WOW - I had to add a ton to GET mine to 1525....even running NiMh...
i've got a brushless 13.5 & Nosram ISTC motor/speedo combination, i have a low profile servo to put in to save a few more grams. I'm coming to the point where 50g is a lot of weight to have and im noticing performance differences compared to a mate thats running the same as i am but bang on the weight he's faster than iam.
Super Moderator
my micro spektrum reciever is on its way, low profile servo is ready to go in, might remove the heatsink for the speedo. don't think there's anything else i can do but drill holes...
Super Moderator
not sure why i had to add a lot of weight to my cyclone to get it to the minimum weight, the cyclone is pretty light
Super Moderator
