Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 05-14-2007, 05:40 AM
  #8371
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
xray bones won't fit the round part where it goes it to the diff is to big
Ron Goetter is offline
Old 05-14-2007, 05:43 AM
  #8372
2-Bad's Avatar
Trader Rating: 24 (100%+)
Speedtech
Originally Posted by Captain Harlock
Does anyone know where can I find the v.2 steel outdrives for the Cyclone?
2-Bad is offline
Old 05-14-2007, 05:58 AM
  #8373
xluis's Avatar
Ok, thanks. But, i install a Xray rear diff, the dogbones are the same long?
xluis is offline
Old 05-14-2007, 06:02 AM
  #8374
Don't think that will work, the bulkheads are farther apart on the Cyclone than on the Xray.
You can use Xray CVDs in the front if you use a one-way, replace the HB one-way outdrives with Xrays and you are set.
vassago is offline
Old 05-14-2007, 06:25 AM
  #8375
thats right but I belive the bones are the same lengh though 44mms
Old 05-14-2007, 06:47 AM
  #8376
Captain Harlock's Avatar
One other question, guys:
Where can I find Square's Pro4 aluminum steering knuckles, blocks and rear upright?
They're out of stock at speedtech, so.....
Thanks.
Captain Harlock is offline
Old 05-14-2007, 08:43 AM
  #8377
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
i belive tower sells them, but why do u want them? i don use them, i got the version 2 steel cvd's up front, but i dont think theres a reason for out drives.......... or wait ur doing a lmt and lipos arent u? im emaxx at rcm
BlackedOutREVO is offline
Old 05-14-2007, 10:03 AM
  #8378
I knew it was you (E-Maxx Rocks).
I actually need the diff joint made of steel or atleast a very tough aluminum.
I think the X-Ray's diff joints will fit. They're long enough and they're 10mm in size. This'll enable me to use the X-Ray's CVDs, too.
I'll get them later, though.
Do you know where can I find alumnium knuckles, blocks and uprights for the Cyclone?
Old 05-14-2007, 02:49 PM
  #8379
hehe
ohhhh ok, i know the xray knuckles work on the cyclone, so the cv's and all MITE fit, but idk i havent ever tried it
and no, just search in google for them, i dont use them, i dont think theres any need really but the way other ppl drive they think so
Old 05-14-2007, 10:02 PM
  #8380
nellguess's Avatar
Cyclone Fanatics-
I just built WCE Cyclone and I just want to ask what's the best servo? Do I need low profile servo?
Also, does anyone put a mamba combo, what's your gearing?
Thanks for your inputs guys.
cheers,
Nellguess
nellguess is offline
Old 05-15-2007, 04:58 AM
  #8381
Wing Chun's Avatar
Trader Rating: 12 (100%+)
Hi guy's
How many of you guy's that have a World's run a rear delrin diff in place of the standard diff and how has it last the distance?
Thanks Addam
Wing Chun is offline
Old 05-15-2007, 05:17 AM
  #8382
Nellguess,
Hi, I'm also from the KSA and I live in Jeddah. How about paying us a visit?
We'll be opening a nice on road track at the Jeddah Race Way, soon.
Well, a standard size servo will work just fine. If you want to be safer, get the low profile.
As for the Mamba Max, I'll be only using the E.S.C with Kontronik's Twist-55 brushless motor and TrakPower's 4900mah lipo pack.
I'd recommend you to get either the 5400 combo or the 6900 combo. Gearing should be a little higher than the equavilent brushed motors.
TRFMAD,
The delrins are tough, but they tend to break at very high stress. I'd go with the aluminum ones.
Old 05-15-2007, 05:36 AM
  #8383
nellguess's Avatar
Captain Harlock-
Thanks for the input, I'll probably order low profile servo, then. Mamba Maxx 6900 is on the kit right now and I'm on "trial and error" gearing combination. What's your gearing right now, for me I will start with Spur=106 Pinion=31. Any inputs on gearing.
Well, how I wish I can visit you there in Jeddah. I'm happy, you're soon having a racetrack. Here in Riyadh, we only run in parking lots more on drag racing.
cheers,
Nellguess
Old 05-15-2007, 06:06 AM
  #8384
mangoman's Avatar
Trader Rating: 11 (100%+)
Ive got a delrin in mine but only running 5 cells. After 1 meet it looks like there is no wear but when setting the diff it felt inconsistent (which is something others had said it would be)
If you go with delrin out drives dont forget to get the retaining rings (in purple of course!!!!)
mangoman is offline
Old 05-15-2007, 12:03 PM
  #8385
This is to anyone...I'm looking for 3 hole 1.1mm pistons for my cyclone. Does anyone know where I can get them or know the part number?
DOTMAN is offline
