Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 01-11-2007, 04:02 PM
  #6646
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
I know I am right thats why I wrenched your car for the mains!!!
HVFracingwilly is offline
Old 01-12-2007, 06:09 AM
  #6647
RMF-888's Avatar
guys does the cyclone spool will fit to the cyclone s?
RMF-888 is offline
Old 01-12-2007, 08:13 AM
  #6648
TcEcho's Avatar
Yes.
TcEcho is offline
Old 01-12-2007, 04:55 PM
  #6649
RMF-888's Avatar
Originally Posted by TcEcho
Yes.
tnx dude
RMF-888 is offline
Old 01-13-2007, 09:39 AM
  #6650
floodo1's Avatar
Originally Posted by rc-zombies
I'm at work right now..don't know the size off hand...should be same size as the top of the shock body.
any shim that will fit... I only had the silver shims not like the plastic ones Hara used. I placed mine inside the cap on top of the bladder.
ahh cmon zombies i thought you knew all things pro4/cyclone
That shim comes with the HPI 40 or 50 or 60 bladders.
I do agree that the best thing to do is just to file the shock cap a little bit. It will turn the edge silver but with the cap on the car you'll never know, and then you dont have to worry about the little shim
floodo1 is offline
Old 01-13-2007, 10:36 AM
  #6651
rc-zombies's Avatar
still using the stock bladders..
haven't ordered the 40/50/60 bladders yet.
that's a few things I forgot to order when I got all the WCE parts last months.
rc-zombies is offline
Old 01-13-2007, 11:16 AM
  #6652
kfa
kfa's Avatar
Do you have a HPI part number ?
kfa is offline
Old 01-13-2007, 02:26 PM
  #6653
pinggoy's Avatar
Trader Rating: 24 (96%+)
whats the use of those kind of baldder.?
pinggoy is offline
Old 01-13-2007, 02:38 PM
  #6654
Tez
just looking at the snowy set up, whats postion four on the camber link?
Tez is offline
Old 01-13-2007, 03:29 PM
  #6655
The Teacher's Avatar
Trader Rating: 62 (100%+)
Hey, do any of you guys run the BMI carpet chassis for the Cyclone??? If so do you have to get different hinge pins for the rear of the car? My chassis has the rear hinge pin mounts spaced out about 3mm longer than the original chassis, was just wondering what hinge pins I need to use (...or do I need to make them)?
The Teacher is offline
Old 01-13-2007, 04:54 PM
  #6656
Static_racing's Avatar
Hey teach,
Use the T2 front hinge pins for the rear of the car. Jason made the rear alittle longer for more tuning options should you need to get the car to rotate harder. I run the med wheelbase on carpet. See you at Mimi's soon.
Static_racing is offline
Old 01-14-2007, 04:11 AM
  #6657
I ran my Cyclone last night in stock with the setup stew noble posted a few weeks back. The car was very good but i feel it could do with a bit more rear traction through the slower corners. It always felt quite twitchy on the back, sometimes the grip was there and other times it was not.
Rick Draper is offline
Old 01-14-2007, 07:03 AM
  #6658
protc3's Avatar
Trader Rating: 13 (100%+)
i ran my car yesterday at our snowbirds warm up race and nailed a really good setup.i TQ'ed and won stock touring.the car was extremely easy to drive and carried tons of corner speed.i will post the set up today
protc3 is offline
Old 01-14-2007, 07:55 AM
  #6659
Thanks Kling, will get some and try it out. I also have a good solution for the servo saver problem you were having, soon as I get the parts I will show you.
Old 01-14-2007, 08:05 AM
  #6660
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
hurry with that set up!!!! Hey Jason lm making a order for parts for the birds let me know what you need!
Marcos.J is offline
