Hot Bodies Cyclone
#5717
Originally Posted by Bjake
Does anyone have setup info for a Cyclone at Speedworld Raceway in Roseville? This is where they just held the 2006 ROAR Nats.
It is a rubber tire/asphalt track.
I've used Hara's Base Rubber / asphalt set-up and it worked pretty good.
#5718
I have a cyclone s and stripped out the plastic pulley. Someone over in the cycone s forum said I would need these to make it stronger.
1 x HB70743 (Direct Layshaft)
1 x HB70711 (Spur Gear Hub)
2 x HB70725 (16T Direct Pulley)
When I look in at the regular cyclone owners manual it shows a different shaft and only one 70725 pulley. I bought the stuff up above and want to make sure I can use it.
Josh
Josh
#5719
Josh
Josh
1 for direct drive and another for use with a center one-way pulley.
#5720
The 70743 shaft is the one I got. So the two pulleys mentioned are the correct ones?
Also, what is the difference in the one way pulley and the other?
#5722
What ball cups do you guys use. And what size?
#5723
Originally Posted by rc-zombies
the one-way pulley is another tuning option. allows the front wheels to free spin.. so no front braking at all. Mainly used for large open tracks.
#5725
Originally Posted by protc3
i have never found it to be good running the spool with the layshaft oneway.the layshaft oneway pretty much defeats the purpose of the spool.
#5726
#5728
I have been using the jet spindles they are good dont bother with the alloy c\hubs as the alloy spindles tend to increase the strength of the composite c\hubs.
Also c\hubs in alloy tend to bend but are very hard to straighten so they are never the same after a big shunt.
Thanks for the advice Jason will try and let you know how it goes, I was looking at Marcos J setup might give it a try as it is very similar to my setup just lower pivot blocks and softer spring rates\oil.
#5729
New cyclone
Ive heard rumours of a new cyclone coming out, does anybody know anything about it (no not the cyclone S)
#5730
anyone got a half decent set-up on concrete using cs-27's? the track is a little bumpy and tight-ish
