Hot Bodies Cyclone
#5026
Originally Posted by dawgmeat
Please help, I'll be soon part of the Cyclone family, the car will have the older black diffs,plan on running carpet and upgrading to the aluminum diffs
1. will the version2 dogbones fits the older diffs or aluminum diffs.
2. Does anybody make a aftermarket diff screw i.e. titanium
3. Cage thrust bearings x-ray, corally or tamiya will they fit the cyclone?
4. des anybody make diffs sheilds for the cyclone, thanks
2. Edit RC Edit
3. I believe the Tamiya fits fine
4. Yes, Jet racing, although they dont work so well on the newer diff pulley, as there designed for the older wider pulley
#5028
Where can I buy a cyclone s?
#5031
Originally Posted by lawtonlosi
How about some steering spindles?
#5033
Originally Posted by Roger
Sorry for being a noobie on the cyclone, but what is a steering spindle ?? Someone also mentioned using a T2 spindle with a .25mm shim ? Could someone clarify this ? Thanks.
#5036
Originally Posted by 2-Bad
Do you have any part numbers handy......
I would recommend getting the diff balls and thrust balls from ACER Racing though. It has always made my diff nice and smooth on previous cars, so I have just ordered some for my Cyclone as well.
And with Diff protectors, I went into a shop just yesterday and bought a Team Atlas set for the TA05 and it fits really nicely, almost as if it was made for the Cyclone (i have the narrower pulleys on my Surikarn Edition) so perhaps give that a go.
I had a look on the Edit Website - the parts look very nice for the Cyclone. Any idea of an online store where I could buy these parts as there is no distributor here in Australia for them??
#5037
the kit doesnt have a part number as of yet.if your LHS would like to put in the pre order they can just call it in.it will have a part number on the invoice for future purchases. i usually dont put kit part numbers into the system until it is ready for release.i should do it earlier to make things easier.
#5038
Originally Posted by protc3
its the steering hub or spindle that your front axles ride through.they are a common part to break on the car when you take a good hit.
#5039
Originally Posted by Skill
Has anyone bought the diff set from Stormer Hobbies? I can't find anything from HB to say they actually do a complete diff set and find it hard to believe that they can sell a full diff set for just $5 more than the price of the delrin outdrives. Is it exactly the same as a standard Cyclone's diff?
