Hot Bodies Cyclone
#3407
Just abit confuse on the droop setting as majority of the setups I have seen have 6mm droop. I was wondering if a ride height of 5.5 mm is still possible. This is on Sorex 36R with C-Med insert and standard rims. I tend to set my car to 3-4 mm droop as I like having the uptravel in the suspension.
#3410
Suspended
i am about to build the diff...is this part any trouble?
#3412
hot off the press. Hara Edition parts list:
ATSUSHI HARA EDITION
61310 Front bulkhead set (purple)
61312 Rear bulkhead set (purple)
61314 Motor mount (purple)
61315 Middle block R (purple)
61316 Upper bulkhead set (purple)
61318 Bearing holder (purple)
61319 Pivot block FR (purple)
61320 Pivot block RF (purple)
61321 Steering wheel arm set (purple)
61323 One-way holder (purple)
61324 Spur-gear hub (purple)
61325 Belt tensioner - mount (purple)
61326 Shock ended ball (purple)
61327 Cylinder upper cap (purple /2pcs)
61328 Cylinder lower cap (purple /2pcs)
61334 Rigid axle set (one piece type/purple)
61335 Aluminum servo mount set (purple)
61338 Aluminum universal bone (purple)
#3413
Suspended
Originally Posted by rc-zombies
nope...
#3414
Has anyone tried a Protoform G6 on their Cyclone its just I like to be different.
I know it was designed for carpet but just wondered if anyone has tried it on asphalt and what was it like?
Tim
Tim
#3415
Is there any online stores which the parts for the Hara edition yet ????
#3417
Do you guys know if a pro4 thrust screw or a screw from any other car will fit?? Now I know why hara and moore ran the Ti one . I broke it running stock which I have never done before.
#3418
You mean Pro 4 diff Screw. Yes it will fit and maybe even Tamiya version as well from the 415/evo 4 models.
#3419
I highly recommend using the TC3 diff screw, nut, washer and spring.
http://www2.towerhobbies.com/cgi-bin...?&I=LXPA07&P=7
#3420
ok cool I like the AE ones I will pick one up.
