Hot Bodies Cyclone
#3286
Originally Posted by cars.cars.cars
Im just wondering if the cyclone or the pro4 Hara Edition has better upgrades, adjustability, price, handling, and durability?
#3287
#3288
Originally Posted by lotus1
Anyone have a definite date for the Surikarn release? To us here in the usa?Thanks,Mario.
Hara Edition will be released in April.
there is no word yet if it's going to be released in the US. I hear rumors that they will not be coming to the US.
#3289
RC Mushroom in HK have them for $455 plus $20 shipping
#3290
Originally Posted by rc-zombies
new pulley won't be available for another month or so..
here are the parts # you'll need: (From the Surikarn Edition)
61050 39T pulley (for ball diff.)
61051 39T pulley (for front one way)
61332 Aluminum diff. cup joint set
61333 Cup joint adapter (2pcs)
61336 Heavy duty front shock tower (3.5mm)
61337 Heavy duty rear shock tower (3.5mm)
61341 Front bulkhead set (blue)
61343 Rear bulkhead set (blue)
61345 Motor mount (blue)
61346 Middle block R (blue)
61347 Upper bulkhead set (blue)
61349 Bearing holder (blue)
61350 Pivot block FR (blue)
61351 Pivot block RF (blue)
61352 Steering wheel arm set (blue)
61354 One-way holder (blue)
61355 Spur-gear hub (blue)
61356 Belt tensioner - mount (blue)
61357 Shock ended ball (blue /4pcs)
61358 Cylinder upper cap (blue /2pcs)
61359 Cylinder lower cap (blue /2pcs)
61363 Titanium turn buckle M3×24mm (blue /2pcs)
61364 Titanium turn buckle M3×34mm (blue /2pcs)
61365 Aluminum color 3×6×0.75 (blue /10pcs)
61366 Aluminum color 3×6×2.0mm (blue /10pcs)
61368 Servo saver post set (blue)
61370 Color wheel nut (blue /5pcs)
61371 Pivot block (2.5 degrees/aluminum/blue)
61372 Pivot block (3 times/aluminum/blue)
61373 Stubby ball set (blue)
61375 Rigid axle set (one piece type/blue)
61376 Aluminum servo mount set (blue)
61377 Aluminum spring mount (blue)
61378 Aluminum universal bone (blue)
#3291
I don't think any of the Surikarn (or Hara for that matter) spares have been released yet.
My Surikarn arrived yesterday and it looks sweet
#3292
so there only gonna release the hara edition to hk etc?
#3293
If that happens then Hara should be banned for any US race meets.
#3295
Anything I need to do to the car before I run it? I set everything up just like in the kit. Partss wise is there anything that makes it alot better or just charge and go!
#3296
Which version did you get? On the normal version I would change the front alloy driveshafts to steel as they can bend very easily even on light taps.
#3297
Evicerator...... how did your Cyclone work in Stockton ?
Did you run the protype BMI chassis ?
Thanks.
Thanks.
#3298
other than that..the car is good to go..
if you're racing asphalt... Try Hara's base asphalt set-up... great starting point.
#3299
