Hot Bodies Cyclone
#2116
oops stormer beat me to it
#2117
For those of you that just bought new cyclones, check this
http://rczone.net/modules.php?name=N...rticle&sid=702
#2118
Mine look better with the limited edition belts
#2119
Trader Rating: 22 (100%+)
Has anyone had problems with the orings in the shocks expanding from the shock oil?
Has anyone had problems with the shocks not sealing properly on the bladder? I tighten the shock cap up and it doesnt seal the shock properly. I had no rebound and very tight shocks so on the exit of corners I had massive oversteer which setup couldn't fix.
#2120
Damn I just got my cyclone, and they have updated verson coming out already?
#2121
oooh .... nice bluey .... time to put in the order
wonder how much it'll cost
#2123
Originally Posted by The Teacher
Can someone be kind enough to post the part # needed to make front diff?
#2124
#2125
#2129
EvilDriver, so the rear diff is the same as the front??? I was under the assumption you had to have different out drives...
however.. I did manage to looked up past posts for you about the front diff.. on this post http://www.rctech.net/forum/showpost...postcount=1901 .. it mentioned about the pro4 diff, one can assumed you could used the out drives from the Pro4.. as you could also use a pro4 spool on a cyclone..but you need to shim the h#$* out of it.. it also said that it uses the CVDs from pro4..
hope some one that have experience in this could chime in and corrected me if i said something wrong....
hope this help..
