Hot Bodies Cyclone
They are pretty similar to sorex. I feel on the first run they are faster than brand new sorexs... but after that they feel pretty equal. I remember running the MM absolutes when I ran for Much More in the past. They work really well too, but justg about any tire worked at the track I ran them at. It was a super high bite indoor asphalt track that made any tire really good!
-Korey
-Korey
Please have a look at the link below (I think you can see it from space!!).
http://www.nearmap.com/[email protected]&nmd=20100216
Cheers
Honestly... I get it with every setup. I've never had a car that didn't do it, so I don't pay attention to it anymore.
On the settings that Korey has used.. what does it do to the rear of the car when you swap the shims in the rear hub / rear arm joint. Does it increase the wheel base and make it less prone to spin from the rear as there is less weight behind the wheel?? or does it do something else.. I usually have the standard settings here which is 2mm at the rear and .7 at the front on the hub joint (don't know what else to call tha area)..
I will give it a go next meet but just want to see what affects on handling I should be looking out for..
Suspended
When I change wheelbase at the hub, it seems to do act a little bit different. I don't notice much change in how much steering the car has, but I notice more about the forward grip the car has. Shorter... more forward grip. Longer... less forward grip. I think it has something to do with the driveshaft angle more than anything, but honestly I almost never play with these adjustments. I leave it all stock pretty much.
In the front I slam the arms all the way back (all shims in front of the arm) to give the shortest wheelbase from the front. Seems like it gives it a little bit more of an edgy feeling (which I like). If you just want to give the car that nice Caddilac feel... lengthen the front.
You might feel something different. Just give it a shot and see what you think. That is what I have found to work for me.
-Korey
Usually it effects how stiff the bladder is and how much rebound will result. Foam is obviously softer than the orings, so it shoul dhave a less aggressive effect. When I run the foam, I usually get a little more rebound than if I didnt use it. I feel it also makes the shock pack up a little quicker since the bladder won't be deflecting as much. This forces the oil through the piston, rather than just moving up the shock body if the bladder were to deflect.
Right now, I usually run zero rebound. I drill a small 1mm hole in the shock cap and dont run any foam. Usually when I build shocks they get a tiny bit of rebound, then it goes away after the first run. Seems to work pretty good for me!
-Korey
-Korey
Suspended
thanks abunch that was exactly was i was looking for
ur the best
-Korey
-Korey
Hi Korey, I'm assuming this is for asphault. Would you drill the cap for carpet of average grip ?
Thanks.
First time on rubber
Hi could somebody please help me
this is my first time racing on rubber tyres
the tyres we use are spec tyres the problem is the car is very loose at the back on and off power after the first 2 min
here is my setup
here is my setup
