Hot Bodies Cyclone
#1846
Originally Posted by pucho
Are those Pro4 outdrives in the front? I spoke with Hara at the nats he told me they would work but in the rear only, wich was strange to me because it should be tha same front and rear. He also told me that the Pro4 spool would work but with lots of shimming and Pro4 axels. What have you guys foun out reguarding this?
Our source for HPI/HB parts does not have the diff outdrives yet, so I made due with what I had. As a bonus, I can run the steel japan-style universals from the pro4.
I never had trouble with wear on my aluminum pro4 spool, rc-zombies...I just kept the driveshaft pins greased (every 3-4 runs) with some of our MP black grease. Plus, it is very cheap, only 13-14 dollars.
#1847
What's everyones solution to raise the roll centre on the FR Pivot block at the front as the steering links hit it. Don't you think it's pretty poor that a top end car like this needs modifications to raise the roll centre, I see Andy Moore has dremelled away part of the pivot block to allow clearance, why couldn't it be like this from the factory?
#1848
#1849
HB Cyclone price is now $419.00 at Speedtechrc.
#1850
#1851
Buyer Beware
#1852
#1853
Buyer Beware
Originally Posted by ogreasurada
www.stormerhobbies.com has been selling cyclone for that price since the first day it came out anyways.
#1856
Originally Posted by HELLOkitty
i got mine for 450.00...
#1857
Buyer Beware
I don't suppose 30 bucks can make any difference on a super car like this anyways.
#1858
very true....
#1859
What's everyones solution to raise the roll centre on the FR Pivot block at the front as the steering links hit it........I see Andy Moore has dremelled away part of the pivot block to allow clearance
I think you answered your own question there, yes at the moment the only solution is to dremel it slightly to allow clearance. If you do do this modification then once youve finished removing the material, use a black permanent marker on the area, makes it looks abit smarter.
Stew
#1860
Bit of sharpie do ya stew!!
