Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 06-08-2009, 10:19 PM
  #16531
bydand53's Avatar
Questions?? Alloy Rear Diff
I've seen a TC with an alloy rear diff.
Where can I get one ?
bydand53 is offline
Old 06-08-2009, 11:04 PM
  #16532
EJ20's Avatar
The one you've seen is an Aluminum Cup Joint #67724, option part for Pro-spec Ball Diff. You can get it at amainhobbies.com or hotbodiesonline.com, they have it in stock.
EJ20 is offline
Old 06-09-2009, 11:38 AM
  #16533
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Originally Posted by BlackedOutREVO
WTH? Did you make that top part of steering? Because I know you cant just flip it like that, the grooves arent lined up like that
Very awesome though!! I love those new FASST RX's! Are you using a 3PK, or 4PK?
I prefer it really. Especially if you run full size RX's, you can move the servo around
Nah, that isnt anything like shoe goo. Doesnt hold sturdy, it flex's around. Goo doesnt
Sorry i'm don't understand ?
i'm changed use 4PK with R604FSE !
RC MARKET is offline
Old 06-09-2009, 12:25 PM
  #16534
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
How did you get the steering setup like that? What did you have to do?
Do those R604FSE work with a 3PK?
BlackedOutREVO is offline
Old 06-09-2009, 12:57 PM
  #16535
RC MARKET's Avatar
not support 3PK !
see photo for stock ESC with Super Cap.
& had rear gear diff.
Old 06-10-2009, 06:25 AM
  #16536
I have been trying to find a track to race my new TC at (Upstate NY). I just built it this spring, but have not yet installed electronics. It's a shame, I love this car. I have a heavily modified Pro3 that I have used for a while. Anyways I am selling the TC in the for sale forums as an SC10 has my attention now. The TC has HB Ti Turnbuckles, HB Aluminum Servo posts, HPI HD ball cups and HPI Purple Shock Nuts for adjusting shocks, HB CF mid plate. Never run before and no electronics installed. As new condition.
If anyone knows of a place to run it near Albany, NY I might keep it, otherwise it is up for grabs. 415 shipped. Pics available.
I wish we had a GT class (like the HPI series) around here. That looks like a lot of fun, and I could bring out the Pro3 for some underdog racing.
[email protected]
-Eric
1999zr2 is offline
Old 06-10-2009, 02:05 PM
  #16537
TheCoolCanFanMan's Avatar
Has anyone fitted the Tamiya 416 shocks onto the TC?
Cheers Malc TCCFM
TheCoolCanFanMan is offline
Old 06-10-2009, 02:31 PM
  #16538
Hi Korey,
In your setup below, you used Losi Shock Oil. I only use only HPI oil. Do you know what are the equivalents for HPI Oil?
Originally Posted by Korey Harbke
Well, I'm back in Bellingham doing the normal school stuff. I'm taking a break from my studies to post up my Reedy Race setup. The car was very easy to drive in the given conditions. Track was pretty high grip, and we were using Jaco Blues.
Front:
Spring: HPI Pro 4 Pink
Oil: Losi 45
Piston: HB 1.1mm 3 hole
Shock position: 3 on tower, 2 on arm
Rebound: Full rebound with no foam
Camber link Position: long, with 2mm under the inner mount.
Camber: 2.5 deg
Toe: 1 deg out
Caster: 4 deg
Toe block: 2.0 deg
Shims under suspension blocks: 1.0mm all around
Swaybar: 1.4mm w/ new style mount, with the screws backed out 3mm
Droop: 9.0mm from the center of the outer hinge pin to the setup board
Ride height: 5mm
Wheelbase: .7mm behind arm, 2mm in front
Rear:
Spring: Silver
Oil: Losi 35wt
Rebound: full without foam
Shock position: 4 on tower, 3 on arm
Camber: 2.5 deg
Camber Link Position: long with 1.5mm under the inner pivot, and 1mm on the outer pivot.
Toe block: 2 deg
Shims under suspension mounts: 1.5mm all around
Swaybar: 1.2mm on new style mount with screws backed out 1mm.
Droop: 8.5mm measured from the outer hinge pin to the setup board.
Ride Height: 5mm
Wheelbase: 2mm in front of arm, .7mm behind it, and 2mm in front of hub, .7mm behind it.
Other:
Front Drive: Ver 3 spool with MIP CVD's
Body: LW Protoform Mazdaspeed 6 mounted a tick forward
Wing: LW wing
Tires: Jaco blue premounts
Sauce: tweak/buggy grip
Motor: Team Trinity Duo 13.5
ESC: LRP SPX
Gearing: 100/40
Hope thats everything! Let me know if you have any questions.
-Korey
billythekid is offline
Old 06-10-2009, 03:04 PM
  #16539
I was told HPI's shock oil weight rating is equivalent to CST exactly. For example, 40 wt = 400 CST. Is this true?
Old 06-10-2009, 03:26 PM
  #16540
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
Well, I asked Hiro at HB. He said that HPI oil runs VERY thin... when I say very... I really mean VERY. He said HPI 80wt is pretty close to Losi 45wt. I have not had any personal experience with this though, so I can't confirm. Hiro is a trusted source though, as he is on the R&D team .
-Korey
Korey Harbke is offline
Old 06-10-2009, 03:39 PM
  #16541
-Korey
Yes, I noticed that. I used run 70 to 80 wt HPI oil in my car. I just switched to HPI molded pistons with really tiny holes, so I can run some where around 40 - 50 wt. I have the entire range of HPI oil, so it would be quite costly for me to switch to another brand.
Any chance Hiro may have the conversion between HPI oil and AE / Losi, or the CST equivalents?
Old 06-10-2009, 03:46 PM
  #16542
Khador12's Avatar
I am going to be racing a 17.5 class and was wondering if lowering the rotating mass would be a big difference?
I was thinking of getting the Edit RC Titanium lay shaft, Titanium Racings spool and cvd's.
Also would ceramic bearings be a good addition? Are there any low friction belts?
Khador12 is offline
Old 06-10-2009, 05:50 PM
  #16543
balistic's Avatar
Trader Rating: 113 (100%+)
I didn't see a US importer for Edit?
balistic is offline
Old 06-10-2009, 06:14 PM
  #16544
I don't think he does. He just knows that by feel/experience... he has those crazy ninja skills you know haha
Old 06-10-2009, 06:18 PM
  #16545
To be perfectly honest... I doubt you'll notice a huge difference. I know it looks good on paper, but whenever I've spent all that money on super lightweight parts I've never really seen it to be worth the cost. I'd save that money for tires!!!
On a side note, The HB ver 3 spool with POM outdrives is actually pretty dang light. I've noticed going to the POM outdrives gives a little more steering, and takes some of the chatter away. Most likely because they fit a little more sloppy. Not sure why they seem to give more steering though... but it's worth a shot!
-Korey
