Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 04-11-2009, 12:15 AM
  #15841
Originally Posted by Tabushi
The problem is, WHICH combination to use ... i mean, here at the forums all people says spurs 70 - 74 ... and pinions on the 33 - 36 range ... and if i see the setups online from cyclone S users on other sites, they say use 100++ spurs and 40+ pinions ... so, where to go ?
Its for 13.5 brushless 6 cells nimh ... asphalt rubber
cya,
Pat
There are 2 ways, use 64p gears and then You will end with using 90-92 spur and 45+ pinions, if you go 48p then it will be around 70 spur and 33 pinion.
Last summer i was using 91 and 51 gears for my Cyclone S(with internal ratio 2.4375).
I don't know condition of your track, but if there is a lot of small stones/dust then i would suggest you to go with 48p gears, as they will strip less. My personal experience with this, as last year I stripped some spurs/pinions due to this fact(was using 64p ones)
janux is offline
Old 04-11-2009, 09:58 AM
  #15842
Tabushi's Avatar
Well guys, downhere in my country its impossible to get locally pinions and spurs so i ordered from rcmart.com this ones :
Kawada brand spurs 66T, 68T and 70T
Kawada brand pinions 32T, 34T and 36T
All in 48 pitch, hope to nail it with it because if not i have to reorder and wait 3 weeks lol !!
thanks for all guys, your posts and private messages has been great help on this my first time on electric touring ...
cya !!
Pat
Tabushi is offline
Old 04-12-2009, 10:09 PM
  #15843
hi-tech-redneck's Avatar
Default fdr for 3.5bl
hey guys need a fdr to start with for my new redline 3.5,just sent my entry off for reedy,so you know the venue,i'm running my same cyclone from the 06 reedy race,well almost the same ,well i'm sure a few of the orignal parts are still on it,its a hara ed.with 3 racing hopups and newer tc bulk heads,with newer 18t center pulleys&belts.been running 10.5 lately just went brushless 7 months ago,any sugestions or starting points would be helpful,thanks!
hi-tech-redneck is offline
Old 04-12-2009, 10:28 PM
  #15844
Trader Rating: 66 (100%+)
Default hara ed. set up
I have a hara ed. cyclone and I'm looking for a good strarting set up for rubber tire carpet with a 13.5. Thanks.
Gwoodrc is offline
Old 04-12-2009, 10:41 PM
  #15845
Default 4 year old tool!
here.s the old girl,it was one of the first batch's of haras that came out, i got it about 4 months before the 06 reedy race!but of course lke all cyclones they morf. over time
Attached Thumbnails Hot Bodies Cyclone-2009_0412image0009.jpg   Hot Bodies Cyclone-2009_0412image0007.jpg
Old 04-13-2009, 05:14 AM
  #15846
R/C Tech Elite Member
Big Midget's Avatar
Trader Rating: 101 (100%+)
Nice car, but whats up with that steering servo? Looks totally different.....
Big Midget is offline
Old 04-13-2009, 07:58 AM
  #15847
fluxhonda's Avatar
it’s probably just a s3002 and a pt taped on the servo
fluxhonda is offline
Old 04-13-2009, 09:01 AM
  #15848
3002 pplleeaassee, its an old 9550 futaba w a chunk of lexan to hold my amb pt
Old 04-13-2009, 10:06 AM
  #15849
Big Midget's Avatar
I wasnt looking close enough this morning
It looked like the servo horn was coming from the side of the servo...my bad
Old 04-13-2009, 10:07 AM
  #15850
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
Originally Posted by Korey Harbke
I have a local race I'm going to this weekend. We have recently lost Seattle Indoor Raceway as the primary indoor racing venue for on road racing. Due to some dedicated racers, they have created a club that races in a old naval base blimp hangar in Seattle, Wa. They are havign their first "special event" race this weekend on the 11th, so I'm going to go support the new club and race with them.
Check it out here:
http://www.seattlercracers.com
There is a possibility I'll be down later this month for some testing though. Some of the Canadians are going to kidnapp me on their way down haha.
-Korey
Seattle RC Racers had recently run their first special event race, and it was a blast. Traction was great as there was a good showing for 1/12 and WGT. My Cyclone was on pace every qualifier (except for me plowing my car into a corner the first round ) and took the Tq position. In the mains, my main competition got caught up in another battle and I went on to win the main. Track was medium grip carpet, here's the setup I ran:
Front:
Oil: Losi 60wt
Spring: HPI Pro 4 Gold
Piston: HB 1.1mm 3 hole piston
Shock position: 2 on tower, 2 on arm
Camber Link Position: Long, with 3mm under inner pivot
Camber: 2 deg
Caster: 4 deg
Swaybar: 1.4mm
Toe in/out: 0 deg
Wheelbase: 2mm in front of arm, .7mm shim behind it (a little shorter than stock)
Ride Height: 4.5mm
Droop: 1.75mm past ride height
Front toe block: 1.5 deg
Shims under suspensiopn blocks: 1.5mm all around
Wheel Hex: std
Ackerman: 4mm
Front Drive: Spool
Other: ATC posts with 2mm shim instead of oring
Rear:
Oil: Losi 60wt
Spring: HPI Pro 4 Blue
Shock position: 2 on tower, 3 on arm
Camber link position: Long on bulkhead, short on rear hub, with 2mm under the inner pivot
Camber: 2 deg
Droop: 2.25mm past ride height
Swaybar: 1.2mm
Rear Toe block: 3 deg
shims under suspension blocks: 1.5mm
Wheelbase: Kit Settings
Tires: Speedmind/Sorex 28R premounts
Traction Compound: Paragon Ground Effects, full front and rear for 20 min
Body: Protoform Mazdaspeed 6 mounted a tick forward
-Korey
Korey Harbke is offline
Old 04-13-2009, 02:42 PM
  #15851
billythekid is offline
Old 04-13-2009, 09:02 PM
  #15852
Default anyone
hay guys anyone have a starting point for gearing on a 3.5 brushless,gonna test sunday at a club race at a local car show,i need a starting point,i,m running a tekin rs pro&matching redline 3.5 thaks guys.
Old 04-13-2009, 09:48 PM
  #15853
Scott B's Avatar
Trader Rating: 47 (100%+)
Assuming your running 5 cell, gear around 8.5-8.6 and check your motor temps.
Scott B is offline
Old 04-13-2009, 10:08 PM
  #15854
Default 7.4lipo
no 5cell i,m throuth with nimh/lipo baby,i'm running checkpoint 5400s but i'm thinking of getting the new 3600 checkpoint that just came out its 30c.does it make much difference between 5cell and 7.4lipo on fdr?
Old 04-13-2009, 10:10 PM
  #15855
STLNLST's Avatar
Trader Rating: 32 (100%+)
Try 9.1
STLNLST is offline
