OS Speed 12 XZ Spec III
woah..the most important question..when is it goin to debut?
Wow!!! This is the boss!!!
So has anyone run this engine yet? Feedback? Is the T-1060 the best pipe?
This Engine won the Japan Nats! And Runner up at the Worlds. I may be running this one this summer! Also they added a new Spring clip exhaust PN.
Press release today: http://www.rccaraction.com/blog/2013...peed-spec-iii/
http://www3.towerhobbies.com/cgi-bin...1992&search=Go
Get it from Champ, cheaper. you can use a Reds/Picco pipe they work great. Engine is a screramer.
so... bought this motor and have run it two race days and a practice and my front bearing was toast.. leaking oil everywhere. clutch was totally full of oil lol.
i wonder if the clutch on my nt1 was compressing the bearings together which caused the front one to prematurely wear?
i tried swapping the bearing with one i had from my old 12tz which was still perfect. easy swap but the same symtom when i reassembled the clutch. less, but still gritty.
installed a xray 0.1mm flywheel shim behind the front bearing on the crankshaft which seems to have fixed the problem as the bearings are no longer under pressure.
i thought maybe i tightened the clutch nut too much but dunno.
anyone else have any issue like this?
thankfully i had a bearing that would work. otherwise id be out of racing this week! guess ill get a ceramic front bearing for replacement.
Also, I have had great luck with Avids ceramic OS bearings! http://www.avidrc.com/product/16/engine-bearings/
