Trinity duo3.5 new motor
#108
So has anyone tried the lot of all the tuning rotors from trinity?
12.3-High RPM
12.3 Wide Power
12.3-Hi-Torque
12.5 High RPM
12.5 Wide Power
12.5-Hi-Torque
??? Just curious on thoughts and how they actually changed the motors? Assuming you have a rather large outdoor asphalt track. I think the stock D3.5 is good but just curious on how you feel it would benefit anything or help out or hurt.
12.3-High RPM
12.3 Wide Power
12.3-Hi-Torque
12.5 High RPM
12.5 Wide Power
12.5-Hi-Torque
#109
The tack that the nationals are on, is well something that most have not seen... If they run the layout that has been talked about, it will make the straightway around 265 feet of 100% full throttle.
Also given that a good bit of the development of this motor was done on this track should give it a leg up....
The top 2 from last weekend had completely different gearing.. One on RevTech with a FDR of 3.65 (box stock motor) and the other had a Duo 3.5 (not box stock) running an FDR of 3.1. The difference was car setup.... The bigger question is what is best for your car setup and driving style... Do you point and shoot, do you rush the corner and crank the wheel, are you Mr. Smooth? All this will change what works best for you...
#110
#111
I will have to watch you next time... When they have the computer connected, stand by it, and take different lines, the result will be your lap times... They say practice makes prefect. I will say Prefect Practice makes prefect.... And you can gain a lot more with prefect practice....
