Wont Stop Glitching... Do I Need Spektrum?
I've been fighting this glitching problem in all my cars for a while now. I'm using a Hitec SRX transmitter sent it back and got a new one and it still glitches. I've tried switching channels, esc's, motors, batteries everything. It does it in all my cars on the same point lap after lap at the track... Any ideas? Will a Spektrum system solve my problem? Is it compatible with the SRX?
Re: Wont Stop Glitching... Do I Need Spektrum?
Can't Have Fun If It Don't Work .....
Glitching !!!
Better of switching manufacture !!!! I went through a long and expensive route with my radio set !!!In the end changed over from a KO stick to a futaba 3VC zuper........no more problems !!!!
Cya
Cya
Try standing in a different spot. If that doesn't work, wrap your head in foil, do ten jumping jacks, spit on the nearest person, then recite "Mary had a little lamb" backwards. That should fix your glitching problem.
....It does it in all my cars on the same point lap after lap at the track...
You wrote "everything", so please forgive me asking: Have you soldered the small caps on your motors? Have you tried moving the RX and antenna as far as possible away from the motors?
And at my experience, the "minus-power-wire" usually carry more noise and sometimes moving that wire just 1 centimeter makes a difference....
Can you show a pic of your car, maybe we can guide you about the wiring?
Which other stuff than the SRX are you using / have tested with?
By the way, at my experience, my Hitec HFS-04MI+ is more glitch resistant than my KO KR 297 Z
Well what alot of people tell me is the crystal could be bad, or u can try putting more capacitors on the motor. the pre-build ones on the motor could be bad. Those would be my 2 things to try.
Hope it helps
Hope it helps
order this from speedtech and all your glitching will be gone
http://www.speedtechrc.com/store/ebp...nid=64&id=2193
