Laptop Rollout chart
rollout
ya i need this also!
Gear Chart
I just use one I built using MS Excel.
Just fill what your spur is, starting pinion size, starting tire size, and Reduction. Then you can save it for a particular car or print it so you don't have to take the laptop
Chart
Here is the file
Here is the one I use for my Pro4.
If your a different ratio, just replace the one that is listed or get rid of it for direct drive cars.
Type in the info in the yellow boxes and it calculates rollout for you automatically in the green box.
http://www.atalantadesign.com/pro4rollout.xls
Originally posted by rcgen
A simple spread should do that for you or go here: http://www.ycityhobby.com/
Josh
Originally posted by karter
So then were does the Tire Diameter go? Im confused now. lol
I'm thinking that they are assuming you are using standard rubber tire size?
Just use the one I posted above and change the ratio for whatever car you are using.
What car are you driving?
