Power Supplies for Chargers
Just wondering what Power Supplies everyone is using (for chargers at home etc so you can save the 12volt car battery for track side charging and topping up batteries)
and if you have any pics of a case you made for a power supply could you post them in this thread, i have an I-Power 12volt 20amp (2 channel) on order from Dinballs RCmart.com, need to make a case for it so its safe and the wiring cant be touched, here's a link to the Power Supply i am getting:
http://www.rcmart.com/catalog/produc...oducts_id=4263
Apprechiate pics and feedback on this one guys, thanks in advance.
I use this one that I got at etronics.com
Works great!
http://www.etronics.com/product.asp?stk_code=pyrps14kx
Works great!
I use modifyed PC power supply. One extra fan for better cooling and 12V output connectors...
My supply gives 16A@12V
Some pictures
Some pictures
thanks for all your info guys, its great to see what power supplies people are using, keep the pics comming
Do you have to put some loads ( ex. resistors ) on 5V line ?
To the guys using PC power supplies... What sorta of whattage power supplies are you using? And did you just clip the extra cables and find the +-12vt DC Leads and wire yourself up some Bananna plugs?
**edit cuz i r spell good
i use promatch power supply it is the same at novak power supply just a little bigger
go to promatch.com to see it
it is only 39.99
late
it is only 39.99
late
i use a pyramid thats older than the titanic.
it wieghs about 20 lbs, is friggen huge. but it works awesome.
15 volts, 25 amps 27 max
will run 3 chargers without sweating, but theres a loose connection in it somewhere that if you hit the table hard enough the alarm goes off and it shuts itself down lol
but i only payed 25 bucks for it
and to get around the huge part i made a distribution box for it, so the haas can sit on the floor and just my chargers and distribution box are on the table.
i love to hate the thing, but it works
I use Duracomm power supplies. I have a 14 amp and a 25 amp. The 25 amp can run a couple of chargers, comm lathe etc..no problem.
I was thinking of making one from PC power supply.
Is it possible to make one giving 20+A ???
I use a PC power supply also. 300 watt or more is best to use. But right now getting away with a 200 watt. Just have to make sure it will put out 10 amps on the 12 volt leg.
The yellow wires are 12 volt lines.
Red wires are the 5 volt lines.
Orange (I think) is 3.3 volt line.
To get the 12 volts to actually put out 12 volts you need to put a load on the 5 volt leg. I use a taillight bulb. 1157 or whatever. A LED would be better as it would put out less heat, and wouldn't burn out.
If using a newer supply, you need to put the red wire and a black wire together from the main connector that is 2 deep by 10 long.
Here's a good thread about it on another forum. Don't mind the pink theme, it's only until Valentines day is over. 12 Volt PC power supply
jbrow1... thats awsome exactly what I was looking for... time to go scavenging at work
