Tamiya F104 Version 2 >
Like Tree2Likes
Old 12-27-2012, 05:39 PM
  #736
celt's Avatar
Originally Posted by Pro10noob
Like this---- bearing then ->)( then the alloy part
Regards Roy
Really? Manual clearly shows the opposite...
bearing --> () <-- alloy spacer
celt is offline
Old 12-27-2012, 07:18 PM
  #737
robk's Avatar
Trader Rating: 22 (100%+)
When using the kit supplied bearing, you set it up per the manual. The one piece thrust bearing requires you to flip the washers since it does not work in the same way the kit bearing does.
If you want, put the thrust bearing together with the washers as the manual says. You will have terrible diff action.
robk is online now
Old 12-27-2012, 09:49 PM
  #738
Pro10noob's Avatar
Trader Rating: 13 (100%+)
Like RobK said
regards Roy
Pro10noob is offline
Old 12-27-2012, 11:16 PM
  #739
Suspended
very nice thanks for sharing
brett546 is offline
Old 12-27-2012, 11:58 PM
  #740
Hi all. We have started running On Road here at Eclipse Hobbies and Raceway in Bradley, IL just south of Chicago. We are currently Running VTA and 17.5T Touring car. Because of my passion for F1 I would really like to get it going here at our track. If anyone is interested please visit www.eclipsehobbies.com and our facebook page https://www.facebook.com/eclipse.hobbies?ref=tn_tnmn
we have a few threads here on rctech also
Ch3no2Phil is offline
Old 12-28-2012, 12:42 AM
  #741
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thumbs up
Nice little track you have there
F1 will be a lot of fun
Best of luck getting it going
RedBullFiXX is offline
Old 12-28-2012, 04:31 AM
  #742
I would be up for on road (F1, Mini, TC, WGT and 1/12) depending on your schedule. Sundays would be preferred.
AreCee is offline
Old 12-28-2012, 06:09 AM
  #743
Anyone planning on going to the tcs race at hobbytown omaha?
Huskerfan1212 is offline
Old 12-28-2012, 10:03 AM
  #744
golgi's Avatar
Trader Rating: 15 (100%+)
Yes, I'm planning to be there at the Plex for TCS. I just got my f104 v2 and will need to dial it in for the track.
golgi is offline
Old 12-28-2012, 12:30 PM
  #745
fleetmaster's Avatar
Trader Rating: 16 (100%+)
Is the version 2 chassis THAT much better, than the F60 kit for example ?
I know you get a bigger window for tuning (for better or worse) , but is this chassis as robust as the t-bar car ??
I'm running indoors, tight , textured surface concrete, 21.5 + rubber tyres.
Won't be buying for a few weeks, but trying to make the right decision !!
fleetmaster is offline
Old 12-28-2012, 01:00 PM
  #746
edhchoe's Avatar
Trader Rating: 41 (100%+)
I just bought a new kit online last night.
edhchoe is offline
Old 12-29-2012, 02:02 AM
  #747
@Edhchoe,
You won't be dissapointed with this chassis, it looks not only good but it drives very good.
I've changed mine to a wide version and this car is very quick, we are using a tamiya 18T sensorless motor and it has a lot of acceleration power.
I was even able to keep up with a 1/12th pan chassis with a 10.5T boosted motor, not so bad if i may say so.
@Fleetmaster,
I've been reading that the weakness of this chassis would be the links, and many drivers changed them for associated ones but so far i haven't got any issues with the links.
I think it all depends on your driving skills, everybody does crash somethimes but it all depends on how big the impact will be.
addicted2blue is offline
Old 12-29-2012, 06:57 AM
  #748
Can someone explain the different in the servo standing vertical vs servo laying horizontal?
Old 12-29-2012, 07:41 AM
  #749
Originally Posted by RedBullFiXX
Hey Juan
We run stock inserts
mostly with 575 rear tires, but TCS tires are very similar
http://uf1rc.com/tamiya-f104v2-setup...-repsol-honda/
The set-up sheet is blank. Is it the same for you?
Juan Aveytia is offline
Old 12-29-2012, 08:05 AM
  #750
Juan
Try saving file, and open with latest vers adobe reader
