Tamiya F104 Version 2
#62
#63
My goodness…
Let me elaborate or at least attempt to, the only difference between the Vir2 diff and the 104pro diff is the actual diff rings and the side of the hub they sit on. All the other components, assembly of the components and adjustments are just like the 104 pro diff. Yes, the wheel has to be removed to adjust the diff. Hope this helps.
Vyg
Vyg
#65
That looks sweet!
All you need is the new Exotek front end and your set.
#66
Very nice! Are the links the same length as the F1R?
#68
Nice...that means I can use my BMI flex links on it
#69
They might fit, the links are very close to the lipo, as Tamiya pulled them in as narrow as possible to clear the body, no trimming or hacking to clear the pods on this chassis, same 104 body pops right on, body mounts are in the same position as well
I used AE Front body post to keep the body hole dia the same for the rear mounts, the kit supplied post are from RM-01, so a a touch larger dia
#72
Trader Rating: 27 (100%+)
#73
Good job! I see noone is using original damper, is it so bad or why? Clever idea those AE post, they are from the 1:12 pan car or from which AE car are they?
