Tamiya F104 Version 2
#271
I wonder if this is only happening on the bench not on the track as nobody seems to be commenting about it
#272
My buddy and I noticed this too when we built ours. We both agreed that it really only looks like it does that at full throw on the bench. It doesn't look like it would go that far over when running on the track. Of course anything is possible if you get tangled with another car.
#274
Hi F1 drivers! We are expecting the new tires (1031 and 1032) next week. Here are some links to reserve your tires:
1031
1032
tire/wheel combo
1031
1032
tire/wheel combo
#275
Nevermind found stock at tqrcracing of the motor mount. Paid more than I wanted to but I really don't believe the stock plastic motor mount is worth running at all.
#277
Enjoy.
#279
A Tamiya Version II finally did well in our race last Saturday, finishing 4th out of 26 cars. And what is strange is the link guys (Exotek and V2) are trying running without side springs and are loving it.
One of the great things about the VII, so much adjustment compared to old t-bar design
#280
I have also found I simply can't get the exotek as smooth/soft in the rear as the v2 even though the v2 springs are stiffer. May have to do with the associated links being a tighter fit than the tamiya ones. Credit to tamiya for getting the v2 spot on.
#281
I always thought going the opposite way would work better. Removing the damper and leaving the springs. I would imagine you need that spring back to centre particularly on corner exit.
#282
#284
I am using a 93/29 ratio with Teampowers 17.5T (200 mm foams) at my local track (58 m straight part) and yes is slow in that part, thinking in adding more punch and/or turbo.
#285
Would the F104 PRO ver.II be able to keep up with the F103's or the F104W(GP)'s?
Cause here in my country we have a mixed field of cars at the race and i don't want to spend money on a car that's only capable of following while it's not able to compete for the first place.
I've been reading a lot of good comments about this car and i'm one click away of buying the car but i just want to make sure it is capable of competing against the F103's etc.
