UFO brushless motor
UFO brushless motor
http://www.redrc.net/2012/05/tianhao...rs/#more-54519
Interesting, besides what looks like a limited timing range, reversing the connections and sensor location makes a lot of sense. That has to keep a noticeable amount of weight more inboard with the wires routed too it and all.
Look close and you can see the vanes for the fan through the holes in the endbell. That needs to go if they want a good motor.
There is no reason to expect performance increase from the design, especially if built to roar specs, there is only so much that can be done. It's a form factor and possibly weight balance advantage, so subtle, but it seems like many are putting a lot of effort into getting low CG and centralized weight these days.
I would also think they could etch timing marks into the top of the can, so you can loosen the outer screws and adjust it without removing the motor.
