For Sale - TRF417 + Lots of spares >
Old 04-23-2012, 06:33 PM
TryHard's Avatar
Default SOLD! - TRF417 + Lots of spares
EDIT - Car is sold, thanks for looking!
So, the time has come to sell my 417... And I'm having a clear out as well (due to relocating) so everything related to the car has to go... it's a long list!
TRF417 - Rolling chassis, freshly rebuilt (including new Smokem chassis plate, and bulkheads) after ATS meeting, used twice since then. Car has cut motor mount, and cut top deck, so only requires shock towers and the lowered king pins to bring up to 417X spec.
Car is also fitted with full Tamiya Ti-turnbuckle set (will include the tools), and Roche spring steel spool cups. Also has a set of ABEC35 ceramic bearings fitted to the car.
Everything in the pictures is included, which included NIP;
Spare Smokem Chassis plate
R1 Works lightweight driveshafts and Axles
42216 - Tamiya steel DCJ's (built, but un-used)
2x 53574 - Damper rod guides
53851 - 46mm hinge pins
54209 - 5mm fluorine ball studs
53850 - Shock piston rod
51443 - Spool drive cups
2x 50380 - E-Clip set
54075 - King pin set
4x 51441 - 113T SpuBr gear
2x 53890 - Swing shaft Protector
51444 - TRF417 cross joint set
51439 - Front belt
54207 - Rear belt
3x 51466 - V2 Gear diff parts
54073 - 1E block
53298 - Wishbones
2x 54031 - C-Hubs
51332 - Steering Knuckle
51333 - Rear hub
Spec R Diff parts (X-rings, Drive shaft caps, hard coated diff joints)
Also included are;
2x Tamiya V2 gear diffs
2x Spec-R gear diffs
Full roll bar set
Large Diameter spring retainer (for HPI springs
Un-cut top deck (for stiffer chassis)
Extra bearings
Big range of suspension blocks (one-piece and splits, and mounting shims)
Painted LTC-R bodyshell
Looking for £325 the lot, shipped anywhere in the world.
TryHard is offline
Old 04-23-2012, 08:44 PM
Trader Rating: 27 (100%+)
An amazing deal!
MDawson is offline
