GT 1/8 Scale Rules and Setup Sharing >
Old 04-27-2012, 06:56 PM
  #256
Pit-racer's Avatar
Originally Posted by Clete Landefeld
Depending on what the rules are.. I am going to run a Houston built motor....I have seen his operation and the inside..of his motors...
Do share some of this info.
Pit-racer is offline
Old 04-28-2012, 07:33 AM
  #257
C-Trickle's Avatar
Originally Posted by VexVegaz
this ofna jp4 pipe is just too damn loud for me. iwas told to use a pipe with 2 chambers or more. does anyone have any experience with a novarosi 2015 pipe on a lrp 30? what would be the best pipe for it that's fairly quiet but does not rob the engine of too much power?
JP4 is one of the quieter pipes. Its a 3 chamber pipe. More Chambers = less sound.
C-Trickle is offline
Old 04-28-2012, 03:23 PM
  #258
VexVegaz's Avatar
Thanks again Trickle.
If that's the case then I'm just lost. is it possible that the jp-4 by design is generally loud compared to other 3 chamber pipes? I'm having a hard time believing that the LRP .30 is just making that much noise on its own even with a INS box installed.
VexVegaz is offline
Old 04-28-2012, 04:04 PM
  #259
C-Trickle's Avatar
I know that the JP4 is quieter than the JP3. Plus the JP4 has better run times. Its very possible that the LRP .30 is an inherently loud engine. I've never personally ran it, maybe somebody who has can chime in on this one?
Old 04-28-2012, 04:15 PM
  #260
MugenDrew's Avatar
Trader Rating: 36 (100%+)
Remember this pipe was designed first for a .21 buggy motor with the aim being great fuel economy, very very smooth or linear throttle response with decent power across the usable rpm range. All of these pipes work with the SOUND pressure wave produced by the engine. So at this point based on displacement you are out of the ball park that the resonance of the pipe was designed around.
MugenDrew is offline
Old 04-28-2012, 09:07 PM
  #261
bassman2's Avatar
If you run a rubber deflector on your JP4 THEN the sound becomes very loud regardless whether you use an INS-box or not. So if you want to reduce the noise from your pipe then run a inx-box without a deflector on your pipe.
bassman2 is offline
Old 04-29-2012, 05:07 PM
  #262
tonylunatic's Avatar
Trader Rating: 45 (100%+)
You guys run PIPES?!?!?!?
Noise!?! I LOVE the noise of PERFORMANCE my NITRO GT8 produces, that why I run Nitro. I would run electric if I wanted to hear swooooossh and my grandmas sewing machine running!!
Hey that's why people go to MotorSport events, to FEEL the noise and excitement!!
tonylunatic is offline
Old 04-29-2012, 07:14 PM
  #263
scary_jerry's Avatar
Smile nitro day
Yeah Tony........
Spooky had twelve drivers turn out for nitro GT practice
today. I went through a half gallon of 'fun juice'. Great session.
THEN.......got home in time to watch the NITRO NHRA from
BAYTOWN/HOUSTON TX!!!!!
scary_jerry is offline
Old 04-30-2012, 09:39 AM
  #264
Vex , I'm afraid that engine IS just loud. I've been around a number of them and it is one of the loudest engines ever.
spooky 1 is offline
Old 04-30-2012, 12:01 PM
  #265
Clete Landefeld's Avatar
So I took the car out this weekend and tried a new clutch.. the BuKu... works great...I like the way it hooked up.... simple design and easy to adjust if needed.... although i didnt touch it... Monty set it for me and it seemed to be fine..
I will rip it out tonight and see if it has any weird wear issues.
Clete Landefeld is offline
Old 04-30-2012, 12:15 PM
  #266
J Lee's Avatar
Yes IMOH, we should keep the clutch rule simple, No centrax clutch. let all the improved clutch from offroad side help us tune our cars. changing stock clutch spring is PITA.
J Lee is offline
Old 04-30-2012, 12:23 PM
  #267
C-Trickle's Avatar
Yes. No to Centax! Cost's and chasing a clutch setup doesn't sound like fun.
Old 04-30-2012, 03:29 PM
  #268
I have those on my other cars... kinda a drag... but if you understand concepts and have a good teacher... they are awsome... Tom Camou from Mugen helped me in the begining and I have never had a problem with them..
I totally agree that they should not be on a GT8 ....
Old 04-30-2012, 03:33 PM
  #269
I concur, no adjustable clutches. And no adjustable diffs.
spooky 1 is offline
Old 04-30-2012, 03:37 PM
  #270
C-Trickle's Avatar
Yes. Gear type diff's and 2,3,4 shoe non-adjustable clutches.
