Brushless VS Brushed motor.
Well I'm sure this has been discussed plenty of times everywhere. I'm going to race a 2wd buggy at my local track and the rules are you can run stock class brushed or brushless motor. Or modified brushed or brushless motor. I'm planing on running in the stock class since I don't wanna destroy my buggy at first run. I haven't ran anything in a race since 97' so I guess I need to get back into the swing of things. I know that we are allowed to run in the stock class 27T brushed or 13.5T about 2500KV brushless motors both motors will give about the same speed. I'm just wondering since I have tons of stock brushed motors (Green Machine2, Slot Machine2, Tamiya Super Stock BZ, Yokomo Super Stock off road) would it be better for me to switch to brushless. I know that when you go higher KV then the Brushless motors shine with speed but will I see better performance out of a brushless motor in stock class. I have some of my on-road cars set up brushless (3000KV, 3900KV) not the fastest motors but they got plenty of speed. I guess I'm trying to see if its worth it for me to invest in a stock brushless set up.
do brushed motors still exist!throw that junk out and spend the money!no comparison.
I ran in a Rally series through the winter, and an asphault TC series last summer where the rule was 27T brushed or 17.5 brushless. I ran brushed, and aside from slight heat concerns I was able to keep up just fine.
A few of the other brushed guys had issues with dirt getting into the motor and causing "hung brushes"...basically, jamming the brush far enough away from the comm that the motor stops.
I think if they are letting 13.5 brushless motors in "stock", I'd rather have run the brushless. 13.5 is definately faster than 27T, and you get to stop worrying about brushes, springs, and dirt crumbing up the motor...
I asked the same question when I got back into rc after a near 20 year hiatus from it. I had nothing but brushed motor experience. Brushed motors are cheap and if you have them then you may as well use them. Especially if you are on a budget. When I bought a brushless motor for the first time I was dumb founded by the shear amount of power that it had. No more cleaning the motor after each run. No motor rebuilds. No brush replacement. Just run it and done. I'm sold on them and am slowly converting everything over to brushless.
If you know it and have it, run it. It may be a good idea to just get out there and practice a bit before you upgrade anyways since in a stock class it's not all about pure speed but rather car setup and driving skill. However if you can afford to go brushless right now, do it. You'll love it.
+1 a 13.5 will blow a 27t brushed away not even close . Most tracks let you run 17.5 or 27t brushed . That being said a perfectly dyno tuned 27t brushed will beat a 17.5 by a little but does not stand a chance against a 13.5 .
Your kidding yo self , 17.5 almost go as fast as a 8.5 now days...
Ive run a Reedy 17.5 in my B4 and it is a rocket with the right gearing.
Also, most 13.5t brushless motors are in the realm of 3000-3300 Kv. Looking at super stock classes, 13.5 brushless motors can run similar lap times to mod motors with a pile of boost.
Go brushless. Way less hassle. No more cutting brushes, lathing armatures, and dyno'ing.
Check again the rules for your track, because 17.5T is the most common off-road stock class. Several companies make really affordable stock brushless systems. You will have to drastically alter your gear ratio, because the brushless motors don't really come alive until they have a certain amount of load on them.
To give you an idea, I found the ideal gearing(for my local track) on my B4 to be 32 pinion, 69 spur. Running a reedy 17.5 on an LRP SPX esc.
Yeah, as has been said. 13.5 is WAY faster than 27 turn. The idea behind stock is 17.5 blinky (no boost) is equal to 27t brushed (and I'd agree with that sentiment for the most part) but if you're allowed boost or more importantly, boost and 13.5 versus 27t. GOT BRUSHLESS.
I should have been more precise in what I was saying . When I said 17.5 I meant 17.5 blinky .
