Best Speed Control for a TC3
What is the best speed control to run in a TC3?
Where is the best place to mount it?
Thanks a bunch
Jon
Madison WI
Thanks a bunch
Jon
Madison WI
Considering the electronics mounting on the TC3 is fairly small, I would get a higher end speedo such as, Novak GTX, basically and LRP Quantum model or any other small one. Mounting should go right behind the servo.
Suspended
for the tc3 the best setup is to put the speedo right in front of the motor and then the reciever between the servo and speedo
Use the Gt7, and the Dually on the other TC3, I have the Rx mounted on the servo which gives me plenty of room for the ESC, Velcro works wounders, RED
Depends how big your receiver is, if your receiver is real big, you'll have to spend the bucks to get a high end, small speedo, like the Quantum 2
