Xray T1FK05
#4036
Can anyone help me with a spec...
27 rubber tire setup on a tight, med grip, Ozite, carpet track?
#4037
Originally Posted by Speedo
I hate the stock shocks so much that I would almost prefer running my car with no shocks at all to building Xray's shocks. Are the Xray pistons a direct fit in the new Serpent shocks, and/or are the Serpent pistons identical to the Xray ones?
#4038
Originally Posted by diesel
Hey Formula1fan, do you need to do any mods to the shock ends to fit on the xray? Can xray springs be used with the tamiya shocks? I assume those are tamiya trf shocks that your using. Thanks.
#4040
Here is a pic of a mod to the impact absorbing lower brace that helps with minimizing chassis splits from front quarter panel hits.
#4042
Originally Posted by L.Fairtrace
Why do you even use that bumper? Just put a pdub bumper on the stock stuff and your good to go. Never split a chassis and dont break much either.
Take a deep breath...wooooooossssaaaaaaaaaaaahhhhhhhhhh...
#4043
Originally Posted by Formula1fan
There was a guy on this form that showed me how to mount them. I have my car tore down since asphalt is done here. I have some of the pictures he gave me if you pm me your email I can send you what I have.
#4045
hey guys
another quick question
the car is together finally
i just put it on the setup board and it is in the blocks to set up the camber and i notice a huge rake from front to rear
what did i do wrong now????
chris
chris
#4047
I am going to buy a pdub bumper after splitting my 2.5mm chassis. It did not take much of a crash to split the original chassis. Look on the bright side, now I can try the 2.0mm chassis.
#4048
Can anyone give me a good starting final drive ratio for a green machine 3 on a FK'05 on asphault and rubber tires?
Thx
Thx
#4049
