Xray T1FK05
#3376
Originally Posted by hpipro321
ya do not use the tamiya shocks ppl at my local raceway tried them u need a lot of modding to the arms and special parts its really not worth it
#3377
keep the xray shock! learn to build them
#3378
I used to be anti xray shocks before I switched to corally, but all it took was actually reading the instructions and DOING THE BLEEDING PROCESS to regain my faith in them. Besides how can you beat the adjustable dampening system.
#3379
I agree, built the shocks with the bleeding process as described in the manual, perfect shocks, don't leak either...
#3381
Originally Posted by Roger
Whats up guys. I tried so mount up some jaco foams to my FK05 and the noticed that the my rear foams are hitting the lower shock plactic mounts. Do I have to grind down the plastic in order for clearence or is there something i should do to run foams ? Thanks for the help.
...you coming down to SWR for the regionals next weekend?
#3382
Yeah, guys, Tag is right.
Using foam inserts not only helps the rebound rate, but also preserves the bladders much longer. Without them, the bladders need to be changed fairly often because they develops cracks from jamming into the plastic circular portion at the top of shock caps.
Also, don't bother with changing over to Tamiya shocks. The stock plastic shocks work super well when assembled properly. Also, the adjustable dampening is a nice touch.
#3383
#3384
sorry for the questions?
Hey guys could I get an opion on a older car in the Xray stable. The T1R chassis. I was thinking about this for 1st eletric chassis. Some thing cheap to fool around with. Sorry this question has probally been asked before.
#3385
A good old strong car its worth the buy if its cheap I have a T1R and T1FK04 and now a FK05 all these cars are run well
Question for 05 drivers
any recommended upgrades (hopups is so tamiya) for Stock and mod racing out doors fast, high grip tar track
#3386
id get the spring steel front axles and a bucket of blades
#3387
A bucket full?
Wont last very long, try a skip full
#3390
It slows down the transfer rate from side to side, thus giving you slower steering response. If the front of your car is reacting too fast on steering response, you can lengthen the linkage.
