Why F1?
For me it was a lot of things. The scale looks are great. Driving a rear wheel chassis is more of a challenge especially on rubber tires. Tuning offers different challenges.
Most of all is the high level of FUN competition. The drivers in f1 are all about fun but still very competitive. There is also a respect between drivers that makes the racing much cleaner. In tc you have a full body so someone never thinks twice about bumping you a little. In f1 the open wheels won't let that fly. There is a lot more concentration on not touching the other car. Wheel to wheel contact usually results in both cars up against the wall. It is just a lot cleaner. Since it is cleaner racing that also translates into less broken arts. Usually when you do break something you know it was your own fault and you earned the repair bill.
It was perfect timing for me. I'm an offroad guy who had a dedicated onroad track open up (very near by) and couldn't let myself squander that opportunity. Personally, I liked being able to get into a class that's on it's way into the mainstream. As onroad tries to reinvent itself, I think F1 is crucial to that success. Onroad needs a cheap, fun class to run, to get people out to the onroad track.
GT8, buggy-based onroad, also covers that, but with a higher budget. I will be racing F1 and GT8, with no plans to get into the established onroad classes. Both these classes will draw offroaders in, as well newbies into the hobby. Our debut race was the 25th, and both classes put on an awesome show. If I wasn't racing or marshaling, I was showing my cars off in the pits.
#20
For me it was the ease of maintenance. There is so little to wear out on these cars it is great. The cost of maintaining F1 cars is minimal also. Then when you factor in the weight and how little power they can handle electronics are easy to get and take little abuse.
Out of all my cars the F1 seems to always be the car that is ready to go. It rarely needs a something fixed before I could take it to the track. I cannot say the same for the TC and defiantly not the off road cars. I think this adds to some of the appeal to F1 since you are spending less time wrenching on the car you spend time making nice bodies or doing things to improve the handling. This is in essence what F1 is all about even in full scale. I do need to get back to working on my diffuser and other aero modifications to my car to see if I can get even better handling.
#26
I didn't see the most important thing: SCALE-looks!
#27
Because that's largely subjective .
I got in because it was a fun class. Close racing, fairly little in the way of setup options compared to TC, and open wheeled pan car. Running with open wheels does teach you to respect each others, not that I don't have wheelmarks on my sidepod... . RWD teaches you to respect the throttle.
It's fairly easy to setup, but I partially disagree on the maintenance. When the class died here in '05 or so we were amazed how low maintenance the TCs actually were, in comparison. No messing around with traction compounds, not having to check height and rollout after each run... of course, we ran neither with hot modifieds, which keps the wear and tear relatively low. Just put it down and go (assuming you had the setup nailed, of course).
Costwise, I'm not convinced it's a cheap class per se.
#29
You nailed it on the cost thing though. No such thing as a cheap class if you want to be competitive but it does seem to be cheaper than a lot of others.
VTA not nearly as cheap to run up front as people would lead you to believe
1/12 too many tires
tc lots of broken parts / worn belts / tires
Anything off road broken parts dirt in every part causing it to wear quickly even more tires
Compared to the other classes I think f1 is cheaper but none of the above is cheap.
#30
I have to agree with the others who state they have a thing for full sized open wheel racing on road courses. It just ends up translating to what I want to play with in my hobby. When I was little I watched Indy on Wide World of Sports, then Monte Carlo on their crappy tape delay: The thrill of victory and agony of defeat. Back then I even knew who Mark Donahue and Peter Revson were. Peter was one of my boyhood heros along with Mark, Mario and AJ. Those men could get in any car and drive it to its limit. It was sad we lost 2 of them too soon. As I can't be an F1 racer, too large, I can put down a car that resembles a real racer and have a go.
